Oil leak press sensor?
TT Paul
Yes Aircon pump off for access, you need to remove a stud as well as a couple of bolts from it. Then you should be able to get a socket on the sensor.
The old sensors were a different size to the revised/better ones, so you may need both a 24mm and 27mm deep socket depending on what size your leaking one is now.
