stevie_b Posted July 13, 2015 Share Posted July 13, 2015 I changed my W58 gearbox oil recently, and the drain plug had quite a lot of metal shavings / filings stuck to it. I've attached a photo, although this was after I'd wiped some off. As you can imagine, I wasn't delighted to see this. Is it normal to see metal filings on the drain plug? I guess it must happen a fair bit for the plug to be magnetic in the first place. I'm trying to figure out if I should be saving for a box rebuild or a good used box. Quote Link to comment Share on other sites More sharing options...
David P Posted July 13, 2015 Share Posted July 13, 2015 That's normal, the magnetic plug is "filtering" the oil and collecting wear and tear debris. Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted July 13, 2015 Share Posted July 13, 2015 what's your mileage and how many owners, is this the first oil change.? I did my gearbox oil last year at 41,000 miles, only one or two bits of swarf was on the magnetic plug. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted July 13, 2015 Author Share Posted July 13, 2015 what's your mileage and how many owners, is this the first oil change.? I did my gearbox oil last year at 41,000 miles, only one or two bits of swarf was on the magnetic plug. My car's done approx 170,000km. About 4-5 owners I think. I've had it for the last 11 years. I had the oil changed soon after I bought it. Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted July 14, 2015 Share Posted July 14, 2015 My car's done approx 170,000km. About 4-5 owners I think. I've had it for the last 11 years. I had the oil changed soon after I bought it. considering the 11 years of ownership and just looking at the superb condition of your car, then it has IMHO been driven well, may be like most of us you can crunch the odd gear change, so i would say the amount of swarf collected over such a mileage and time is within normal wear and tear. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted July 14, 2015 Author Share Posted July 14, 2015 considering the 11 years of ownership and just looking at the superb condition of your car, then it has IMHO been driven well, may be like most of us you can crunch the odd gear change, so i would say the amount of swarf collected over such a mileage and time is within normal wear and tear. Thanks for the feedback, and kind words about the car! You have a W58 in your supra don't you? Do you have to push the clutch pedal down really hard to get a smooth change from 1st to 2nd? Almost like you're trying to push it into the engine bay? Mine's like that. I'm pretty sure my floor mat isn't stopping the clutch, but I'll check again. Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted July 14, 2015 Share Posted July 14, 2015 Thanks for the feedback, and kind words about the car! You have a W58 in your supra don't you? Do you have to push the clutch pedal down really hard to get a smooth change from 1st to 2nd? Almost like you're trying to push it into the engine bay? Mine's like that. I'm pretty sure my floor mat isn't stopping the clutch, but I'll check again. Looks like your clutch needs bleeding and or a change of fluid, not sure if or you can adjust the travel on these cars? as i have only done this on other cars etc, it could be a self adjusting design? in which case your pressure plates could be getting worn,? someone on this club will know. If the clutch is hindering your gear changes as you describe, then this would not help the normal wear on the gearbox. Hope this helps. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted July 14, 2015 Author Share Posted July 14, 2015 OK thanks, I'll start a new thread about the clutch pedal feel to avoid going off-topic in this thread. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 14, 2015 Share Posted July 14, 2015 Doesn't look too bad, manual gearboxes always create some debris off the synchro hub teeth and elsewhere. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted July 15, 2015 Author Share Posted July 15, 2015 Thanks all, I appreciate the advice. I'll file this under as normal wear and tear. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 15, 2015 Share Posted July 15, 2015 He says, as it starts jumping out of gear next week..... Quote Link to comment Share on other sites More sharing options...
