jza800 Posted July 11, 2015 Share Posted July 11, 2015 Hi i broke my Fan Shroud tonight, i have have 2 choises.. remove the broken one and drive the car without the Fan Shroud to i get a replacement, or mount my 2 x 1000 cfm fans... So what can i do Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted July 11, 2015 Share Posted July 11, 2015 If you are planning to put a stock fan shroud back on. Then if it was me i just drive it without one for now. Save you the hassle in wiring up the electric fans. Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 11, 2015 Share Posted July 11, 2015 +1 for running without the shroud unless you were planning on mounting the electric fans anyway Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 11, 2015 Share Posted July 11, 2015 Ask yourself, what does a fan shroud do. Then bear in mind its summer. Do you live in a busy town/city? Do you spend a lot of time sitting in traffic? Running without a shroud is akin to engine suicide IMO. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 12, 2015 Share Posted July 12, 2015 A brand new shroud from Toyota is a little over £100. Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 12, 2015 Share Posted July 12, 2015 I ran mine for over a year without one and never saw the temp move above the half way line. But then I don't think I ever sat in traffic Quote Link to comment Share on other sites More sharing options...
fastcar Posted July 12, 2015 Share Posted July 12, 2015 I have a complete TT shroud if you need it dude. Give me a PM Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 12, 2015 Author Share Posted July 12, 2015 I was planing to run the 2 x electric fans, but as i had diffent opinios off runnng those, as they say thay move to little cfm, i usede the stock fan and shroud, but as that i total broke now i was thinking off the electric fans now.. the company said they move 1000 cfm off air each, i am not useing my car to track or road race, my engine is close to stock.. only fmic - aftermarked oil cooler and recloations kit, and a boost controller to i can raise the boost to 1.2 if i want.. Can og Can i not use those fans??? Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 12, 2015 Author Share Posted July 12, 2015 (edited) i have now decided to use the electric fan as i have to get the car running to next weekend, but can i use this way to wire it in, so when the switch is off the fans run by the org switch in the bottom off the radiator, and when i turn the switch on, i overide the switch and the fans turn on??? Edited July 12, 2015 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 13, 2015 Author Share Posted July 13, 2015 Anyone Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 14, 2015 Author Share Posted July 14, 2015 Bump Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted July 14, 2015 Share Posted July 14, 2015 I am not much of a electrical person. I recently installed one of these and the instructions were easy enough for me to follow. You can install a bypass switch but I didnt, everything is compact and most of all tidy. http://www.revotec.com/acatalog/Electronic-Fan-Controller-Threaded-Fitting.html This is the fitting instruction I used. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 14, 2015 Share Posted July 14, 2015 Repair or replace the shroud as soon as you can. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 14, 2015 Share Posted July 14, 2015 Without a shroud the fan will spend more time just stirring the air up in the bay, with the shroud in place it will draw air through the rad far more efficiently than without Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 14, 2015 Author Share Posted July 14, 2015 I want to mount the electric fans as o have to use the car to show this weekend, so cant get a hold in a replacement, so the electric must be better than without, there is a shrould to the electric fans.. so just the wirring i need help to Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 15, 2015 Author Share Posted July 15, 2015 I now got my fans on, and put them to a switch inside the car, so i can turn them on manually Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 15, 2015 Share Posted July 15, 2015 They are turning the right way, aren't they> I had a car which was overheating and they were blowing forward..... I have to say blocking the matrix with a plate like that is REALLY bad.... Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 15, 2015 Author Share Posted July 15, 2015 Yes when they turn on, they are blowing to the engine side, not intercooler side.. matrix do you mean radiator??? if yes i now so, but i have to use the car this weekend, and cant get a replacement to weekend.. thats why i had too Quote Link to comment Share on other sites More sharing options...
