Fan Shroud problems
jza800
I was planing to run the 2 x electric fans, but as i had diffent opinios off runnng those, as they say thay move to little cfm, i usede the stock fan and shroud, but as that i total broke now i was thinking off the electric fans now.. the company said they move 1000 cfm off air each, i am not useing my car to track or road race, my engine is close to stock.. only fmic - aftermarked oil cooler and recloations kit, and a boost controller to i can raise the boost to 1.2 if i want.. Can og Can i not use those fans???
i have now decided to use the electric fan as i have to get the car running to next weekend, but can i use this way to wire it in, so when the switch is off the fans run by the org switch in the bottom off the radiator, and when i turn the switch on, i overide the switch and the fans turn on???
Edited by jza800 (see edit history)
I want to mount the electric fans as o have to use the car to show this weekend, so cant get a hold in a replacement, so the electric must be better than without, there is a shrould to the electric fans.. so just the wirring i need help to :)
Yes when they turn on, they are blowing to the engine side, not intercooler side..
matrix do you mean radiator??? if yes i now so, but i have to use the car this weekend, and cant get a replacement to weekend.. thats why i had too
