Brake Bleeding Issues
MKIV-Supra
Hey Guys,
i changed the Front and Rear brakes, because the weren't good as i bought the car. When i bought it, the Pedal felt spongy. So i changed the brake fluid too. Then i saw, that the Brake master cylinder was leaking and the Seals were Bad so i bought another one.
I changed it and bleeded the brakes again.
If the engine is off, the Pedal is hard.
When i Start the engine the brake is too spongy so that i have Air in the system.
I think its in the ABS Block. I dont have TRC.
How do i bleed the ABS Block now?
I dont have the SST as it's shown in the manual. I can pull the relay out and Start the pump, but how can i open the valves to bleed it?
Does someone know the wiring which pin i have to close?
Please help me!
Greetings and sry for my Bad english.
Damien from Germany
Unless someone has fitted the calipers on the wrong sides. I know someone who did that, and spend months chasing a spongy pedal :innocent:
Easy enough to check that, the bleed nipple should be the highest point on the caliper, arrowed in green on my car
Try bleeding it, with very slow pedal depressions and equally slow releases, when the nipple is closed, with the engine idling.
I have vacuum and pressure bleeders, but can't recall when i last used either. I never seem to have an issue bleeding conventionally. No pumping of the pedal, slow and smooth, up and down. Tissues matron, quickly now.
Calipers are right mounted. I bleeded the calipers with very slow pedal, then with vacuum 2 times and at least 3 times with pressure bleeding set at 0.7 bar. It's now a little better. I have now 10cm from the ground to the Pedal, when engine is running and Pedal is complete pressed.
Toyota says min. 7cm.
Can some one agree that it's now okay?
£130 DNK!!!!
Do you also have a link or discount code for your money tree? :D
This is a workshop model that's used for all sorts of fluid evacuations etc :)
There are DIY home mechanic vacuum bleeders for under £40
I've got one of the small hand-held vacuum bleeders. You connect it up, then pump the handle to make a vacuum... except that I've never been able to make it work properly. It was only £15-20 so the old adage of you get what you pay for seems to hold true. I can't remember the details of my issues, something to do with not getting a decent airtight seal between the bleed nipple and the tube, and/or not being able to loosen/tighten the nipple whilst the tube was fitted.
I enlisted the help of a glamorous assistant instead, and achieved a good bleed.
Toyota say a MINIMUM of 7 cm's? Or a MAXIMUM? Removing anti squeal shims or backing pads will help. Clamp (sypathetically) each rubber brake hose near the caliper, does clamping one in particular reduce pedal travel especially? Look closely at that caliper and pad arrangement. DO NOT clamp braided hoses!!
The "special service tool) is just a link to bypass a relay's power contacts and run the ABS pump continuously. Just a bit of wire or a paper clip can be your "special tool" :)
I have braided hoses so i cant clamp it. How do you mean that, removing shims will help? Everyone says they have to be there. Should i remove then completely?
I just know the Pedal from my old bmw's with braided hoses, the Pedal was very good. I had a good feeling from beginning an could only press the Pedal 5cm down till i Stand.
Maybe someone can make a Video of his brake Pedal when the engine is running.
I bridged the relay or the Abs pump Motor, but bridging Alone wont help i think, when the valves are closed?
Edited by MKIV-Supra (see edit history)
So i should remove the squeal shims and test it then? They didnt look so good to me,too but i thought i should put thenm better in. The rattle spring over the pads should i better installed, am i wrong?
On the back of the pads a layer off ceramic grease should stop squealing too?
If they are the J-Spec calipers make very sure the slider pins are totally free to move and grease them with black moly grease (like you would use in C/V joints).
I removed the wide rubber O-ring thing on the end of my pins: they were causing the pins to jam in their housing.
