jon_dragon Posted July 9, 2015 Share Posted July 9, 2015 Hi peeps! I'm moving away from the viscous fan setup and going twin electric. How has everyone wired the fans? Quote Link to comment Share on other sites More sharing options...
fastcar Posted July 10, 2015 Share Posted July 10, 2015 Hi peeps! I'm moving away from the viscous fan setup and going twin electric. How has everyone wired the fans? If you have a look on power house racing there is a twin fan electric loom the uses the stock thermostat to switch the fans on at 97c Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted July 12, 2015 Share Posted July 12, 2015 It depends what wattage your proposed fans will draw. Mine are 80w each, so when they're running they draw circa 11a with the engine running. The factory wiring is rated to 15a, so I connected mine to the stock plug. If you choose higher rated fans, you'll likely need to wire them through a relay Quote Link to comment Share on other sites More sharing options...
jon_dragon Posted July 23, 2015 Author Share Posted July 23, 2015 http://www.powerhouseracing.com/p-4603-phr-pnp-harness-for-is300-fan-kit.aspx Your joking, right? Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 23, 2015 Share Posted July 23, 2015 I have maid my own wirring loom to my electric fans, each fan as is own relay, then to a switch inside the car to turn them on.. want to wire it to the stock thermostat but that dident work... so just have the switch inside the car i turn them on manually.. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted July 23, 2015 Share Posted July 23, 2015 I bought an eBay Spotlight wiring kit and Just adapted it Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted July 23, 2015 Share Posted July 23, 2015 (edited) Am i right in thinking that you are fitting the electric fans not just to save a little horse power.? but more to keep your engine cool because you have a tuned tt or an NA/T, which produce more heat.? I ask this as my NA has never overheated in 20 years even in mega traffic jams in a hot summer day. What sort of money are they and where do they fit if you have a IC? Edited July 23, 2015 by herbiemercman (see edit history) Quote Link to comment Share on other sites More sharing options...
AndyJax Posted July 23, 2015 Share Posted July 23, 2015 I've been led to believe that the standard viscous fan is more than up for the job unless its massive BHP. Is it really worth it for the sake of gaining a bit more power the trouble of fitting and setting up electric fans.Prepares to be put right! Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted July 24, 2015 Share Posted July 24, 2015 Thanks Andy, that figures with my experience. Quote Link to comment Share on other sites More sharing options...
