T2 MSW Posted July 8, 2015 Share Posted July 8, 2015 I have wired up my separate fuel pump power feeds. Looking at configuring the second pump and I need to configure the pump on duty. What do people recommend as a percentage to enable the 2nd pump? Do you also need to configure the hysteresis or should that be left at 0%? Cheers Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 9, 2015 Author Share Posted July 9, 2015 Anyone?? Quote Link to comment Share on other sites More sharing options...
fastcar Posted July 11, 2015 Share Posted July 11, 2015 Might be best to give Ryan G a PM about this, he is the man who is likely to know:) Quote Link to comment Share on other sites More sharing options...
hodge Posted July 15, 2015 Share Posted July 15, 2015 The 2nd pump is usually set up on a syvecs to turn on at 7 or 8psi. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 16, 2015 Share Posted July 16, 2015 If the turning on of a second pump results in an increase in rail pressure, then you need dual maps. Make sure the rail pressure does NOT change. I personally avoid dual staged pumps. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 16, 2015 Author Share Posted July 16, 2015 The 2nd pump is usually set up on a syvecs to turn on at 7 or 8psi. So that would be about 20-25% duty? Only options you have now is % duty on for second pump? Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 16, 2015 Author Share Posted July 16, 2015 If the turning on of a second pump results in an increase in rail pressure, then you need dual maps. Make sure the rail pressure does NOT change. I personally avoid dual staged pumps. Pressure is managed by the external FPR and Im assuming the syvecs manages/expected the transition of an additional pump coming on line. All big singles that I know off running Syvecs dual stage pumps in this way. I did some datalogging last night and did not see any spikes in FuelPressure and a minor blip into the low 11s on the AFR. Quote Link to comment Share on other sites More sharing options...
