Replacing all oil and coolant
Guest Lol Dude
Guest Lol Dude
I am about to replace all oil and coolants for my 94 N/A Supra but I'm not sure if I am getting the right stuff and don't want to waste my money. I've followed two guides which I will link below but not everything from them is available so I have had to choose different stuff and I have no idea what to look for in oils and coolants. Anyway, I would just like someone to go over my list and check that everything is all good before I purchase. Thanks
My list:
Guides:
http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine
http://mkiv.supras.org.nz/techo.htm
Your list looks fine to me. I recently did a full service to mine and had a similar looking list, the only thing that was different with mine was the use of ATF II powersteering fluid rather than ATF III, just because the stock power steering cap says to use ATF II on the inside.
However I'm pretty sure there isn't much difference betweeen the two types.
