skyes aero Posted July 6, 2015 Share Posted July 6, 2015 Hi, I want to remove the fuel tank for some wielding and rust proofing , I have striped most of it down just not sure were to disconnect the pipe work to lower the tank out ? I have a NA import. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 7, 2015 Share Posted July 7, 2015 You disconnect it in the boot area the pipework is under the black cover in the boot, with the fuel pump etc, iirc theres a couple of pipe clips to undo on the top of the tank Quote Link to comment Share on other sites More sharing options...
skyes aero Posted July 7, 2015 Author Share Posted July 7, 2015 Cheers mate, nearly out , what about the pipe that's bolted on should this be disconnected ? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 7, 2015 Share Posted July 7, 2015 Yeah un bolt/takeoff any pipes under the cover in boot, tyeres one bolted one and the rest (3?) are clips iirc Quote Link to comment Share on other sites More sharing options...
skyes aero Posted July 7, 2015 Author Share Posted July 7, 2015 Its out! , fuel line bolt gave a good fight Quote Link to comment Share on other sites More sharing options...
