scottybennoch Posted July 6, 2015 Share Posted July 6, 2015 Hi all after a little bit off help!! I am really struggaling to remove my drivers seat... There is a harness clasp stuck down the left hand side and the driver seat is stuck all the way back.. I can't get to the clasp to remove it and i can't get to the back bolts to remove the seat.... I was thinking is there a way to strip the seat down from the top?? Or does anyone have any ideas?? Thanks in advance any help would be brilliant Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted July 6, 2015 Share Posted July 6, 2015 (edited) Hi mate I had the same problem. If you look on the left side at the front of the runner there is a bolt think it's a 13mm I put a ratchet on it and done it manually forward All the way then was able to undo the back bolts. Hope this is of some help. Assuming it's the same as mine Mine is electric. Edited July 6, 2015 by sidewaysdan (see edit history) Quote Link to comment Share on other sites More sharing options...
scottybennoch Posted July 6, 2015 Author Share Posted July 6, 2015 When i do that the bolt just comes off it doesn't move forward Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted July 6, 2015 Share Posted July 6, 2015 Are you sure it's the right bolt. As on mine it's like a really long screw when I turn it it moves the runner forward/backwards I then use the electric to move the other side at the same time. Quote Link to comment Share on other sites More sharing options...
scottybennoch Posted July 6, 2015 Author Share Posted July 6, 2015 I think so but im not 100 percent!! Dnt supose you have pictures of were the bolt is Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted July 6, 2015 Share Posted July 6, 2015 (edited) Found this thread There is a plastic plate at the front of the seat, two screws. Once removed you will see two gold coloured nuts, one on each side of the seat. If you turn the nuts the side of the seat will move backward and forward. You should basically move each nut one after the other say three turns as the seat starts to twist and get jammed in the runners if you don't. Problem is, if the seat is in the far back position, turning the nuts clockwise can actually undo them from the thread. If the seat is forward, then turning them is not a problem as you are tightening the nut with the motion and the seat will go backwards. When removing my seats from the NA after the mechanism failed, my nut came off as I tried to draw the seat forward and I ended up needing to either weld the nut on or bash the end to ensure the nut could never come off again. Edited July 6, 2015 by sidewaysdan (see edit history) Quote Link to comment Share on other sites More sharing options...
scottybennoch Posted July 6, 2015 Author Share Posted July 6, 2015 Lol trust it to be my luck its all the way back haha!! Thanks for thats help mate i will give it another go tomorrow!! Fingers crossed! Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted July 6, 2015 Share Posted July 6, 2015 Maybe if you could get another nut on the end and then try. Pain in the but i know when I had to do mine took some time to workout the best way. Hope you get it sorted mate Quote Link to comment Share on other sites More sharing options...
scottybennoch Posted July 6, 2015 Author Share Posted July 6, 2015 I will give it a good go after work tomorrow And report back Quote Link to comment Share on other sites More sharing options...
scottybennoch Posted July 7, 2015 Author Share Posted July 7, 2015 All sorted!! Stock seats out new seats in! Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted July 7, 2015 Share Posted July 7, 2015 Nice one mate :-) Quote Link to comment Share on other sites More sharing options...
