emanage ultimate jumper settings
jawan
need help with jumper settings for EMU
which ones to leave open
which ones 1-2 and which ones 2-3
found some info but not sure on the rest.
JP1
JP2
JP3
JP4
JP5
JP6
JP7
JP8 2-3
JP9 open
JP10 1-2
JP11 1-2
JP12 1-2
JP13 1-2
JP14
JP15 1-2
JP16 1-2
JP17 open
JP18
JP19
JP20
thanks
  • 1 month later...
This is how mine is setup. My EMU is a series "D"
J1 OPEN injector input/output "trim and add"
J2 OPEN injector input/output "trim and add"
J3 OPEN injector input/output "trim and add"
J4 OPEN injector input/output "trim and add"
J5 OPEN injector input/output "trim and add"
J6 OPEN injector input/output "trim and add"
J7 1-2 ignition input signal "normal"
J8 2-3 ignition output signal "12v"
J9 OPEN airflow input/output signal "normal"
J10 1-2 airflow signal input2 "GTR RB26DETT"
J11 OPEN Option 1 "pressure or A/F sensor"
J12 OPEN Option 2 "pressure or A/F sensor"
J13 OPEN Knock signal input1 / water temp sensor "knock sensor"
J14 OPEN Knock signal input2 / intake temp sensor "knock sensor"
J15 1-2 RPM signal input "tach signal from ECU"
J16 1-2 Frequency input signal / VTEC "VTEC input"
J17 OPEN Frequency output / VTM "Karman airflow meter output"
J18 OPEN Injector input / output signal CH1-6 "trim and add"
J19 1-2 Injector signal CH-A "sub injector or NVCS relay"
J20 1-2 Injector signal CH-B "sub injector or NVCS relay"
