jawan Posted July 4, 2015 Share Posted July 4, 2015 need help with jumper settings for EMU which ones to leave open which ones 1-2 and which ones 2-3 found some info but not sure on the rest. JP1 JP2 JP3 JP4 JP5 JP6 JP7 JP8 2-3 JP9 open JP10 1-2 JP11 1-2 JP12 1-2 JP13 1-2 JP14 JP15 1-2 JP16 1-2 JP17 open JP18 JP19 JP20 thanks Quote Link to comment Share on other sites More sharing options...
Durandal Posted August 9, 2015 Share Posted August 9, 2015 This is how mine is setup. My EMU is a series "D" J1 OPEN injector input/output "trim and add" J2 OPEN injector input/output "trim and add" J3 OPEN injector input/output "trim and add" J4 OPEN injector input/output "trim and add" J5 OPEN injector input/output "trim and add" J6 OPEN injector input/output "trim and add" J7 1-2 ignition input signal "normal" J8 2-3 ignition output signal "12v" J9 OPEN airflow input/output signal "normal" J10 1-2 airflow signal input2 "GTR RB26DETT" J11 OPEN Option 1 "pressure or A/F sensor" J12 OPEN Option 2 "pressure or A/F sensor" J13 OPEN Knock signal input1 / water temp sensor "knock sensor" J14 OPEN Knock signal input2 / intake temp sensor "knock sensor" J15 1-2 RPM signal input "tach signal from ECU" J16 1-2 Frequency input signal / VTEC "VTEC input" J17 OPEN Frequency output / VTM "Karman airflow meter output" J18 OPEN Injector input / output signal CH1-6 "trim and add" J19 1-2 Injector signal CH-A "sub injector or NVCS relay" J20 1-2 Injector signal CH-B "sub injector or NVCS relay" Quote Link to comment Share on other sites More sharing options...
jawan Posted August 15, 2015 Author Share Posted August 15, 2015 thanks mine is Series E and has extra jumper 21 ,which is set to 1-2 Quote Link to comment Share on other sites More sharing options...
