Poshmalc Posted July 2, 2015 Share Posted July 2, 2015 Hi guys, I just managed to trap the wire at the bottom right of this picture behind my thermostat pipe and tightened it up and I'm worried that the fact the car won't start now may be caused by this. Does anyone know what these wires are for? If it is the Water Temperature Sensor, then it kind of explains it all as it won't start without this! Any help would be really appreciated. Many thanks, Matt Link to comment Share on other sites More sharing options...
Dim Sum Posted July 2, 2015 Share Posted July 2, 2015 Looking at it from this angle, it could be the crank sensor. Is it the black wirer connected to the alternator? Link to comment Share on other sites More sharing options...
Poshmalc Posted July 2, 2015 Author Share Posted July 2, 2015 No mate, I don't think so! It always gets in the way when you tighten up the two nuts on the thermostat pipe. Link to comment Share on other sites More sharing options...
Poshmalc Posted July 2, 2015 Author Share Posted July 2, 2015 Looking at it though, you could be right?? Link to comment Share on other sites More sharing options...
Poshmalc Posted July 2, 2015 Author Share Posted July 2, 2015 Is the crank sensor connected to the alternator? Would it stop the car starting if this was damaged? Link to comment Share on other sites More sharing options...
Lee P Posted July 2, 2015 Share Posted July 2, 2015 That cable is the crank sensor and yes will stop the car starting if it's cut through or shorted together. Link to comment Share on other sites More sharing options...
Poshmalc Posted July 3, 2015 Author Share Posted July 3, 2015 Cheers Lee, I'm guessing that's what's happened! Link to comment Share on other sites More sharing options...
