jza800 Posted July 1, 2015 Share Posted July 1, 2015 (edited) I have had the car to a a/c service to refill my a/c system, after i have been apart.. the a/c pump starts, but stops after a couple off sec, and the a/c blinks in the dash, what is my problem??? toyota sayes 700 - 750g, and he put 700g in.. and he vacum the system for 30 min Edited July 3, 2015 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 1, 2015 Share Posted July 1, 2015 search for 'aircon fault code' in the advance search and there are a few threads where you can run a diagnostic on the aircon, I'd do that first Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 1, 2015 Author Share Posted July 1, 2015 i did that. no error codes.. Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 1, 2015 Author Share Posted July 1, 2015 it is this you mean right??? http://www.jack-frost.co.uk/toyota_supra_air_con.html i light in both in 3.. witch should be like normal.. no errors right???? Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 1, 2015 Share Posted July 1, 2015 yes, try watching the sight glass near the front bumper somewhere......might need someone else to press the button while you watch, can't remember now. http://www.mkivsupra.net/vbb/showthread.php?312794-Air-Con-Diagnostic-codes&highlight=sight+glass Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 1, 2015 Author Share Posted July 1, 2015 i have looked in the glass, and i can see fluid in there.. Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 1, 2015 Share Posted July 1, 2015 It 'could' be the valve behind the dash that I had but I was advised it was this by a aircon specialist I couldn't say for sure it is that in your case. But if the system isn't leaking and the compressor is working then it points to no flow excess pressure....however there is an error code for abnormal pressure so it's odd this doesn't show? I'm sure a decent experienced aircon guy could tell you or at least rule many things out. Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 1, 2015 Author Share Posted July 1, 2015 i have now tried again to look in the glass, and now i was empty, if i shake it a little, the fluid get viseble and i starts to bubble a little. if i start up the car and activte the a/c, i baraly reach the glass before the a/c pump stops, i can then see the fluid total fill the glass, then it slowy disappear again so i baraly can see the fluid in the glass.. Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 1, 2015 Author Share Posted July 1, 2015 i hve now tried to take the relay out off the fusebox inside the enginebay, now i can turn on the a/c and it will not start to blink at all, as soon as i put the relay on again and the clutch engage, it only engage a couple off sec and then turn off again, and the a/c button start to blink again.. can some off this info help you to diagnose my problem??? Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted July 1, 2015 Share Posted July 1, 2015 I had this issue in my old Supra and it turned out to be the expansion valve. That's the thing Scott was talking about behind the dash. Simple job for an aircon specialist. Quote Link to comment Share on other sites More sharing options...
jza800 Posted July 2, 2015 Author Share Posted July 2, 2015 And you had the same symtoms as i have? Quote Link to comment Share on other sites More sharing options...
