JackyBoi Posted July 1, 2015 Share Posted July 1, 2015 He's just spent over £300 having his steering rack and sub frame sorted out, only to then be left with this. His engine sounds like it's misfiring on revs, and also a hell of a lot of white smoke from exhaust. See the video: https://vimeo.com/132317509 Any help at all would be hugely appreciated. If it helps the HT leads have been replaced recently. Thanks guys! Link to comment Share on other sites More sharing options...
stevie_b Posted July 1, 2015 Share Posted July 1, 2015 White smoke is often water (or coolant). Is the engine oil and coolant clean? No mayonnaise? Link to comment Share on other sites More sharing options...
Benjy Posted July 1, 2015 Share Posted July 1, 2015 Coil pack or something sinister I suspect. How much smoke? Link to comment Share on other sites More sharing options...
JackyBoi Posted July 1, 2015 Author Share Posted July 1, 2015 White smoke is often water (or coolant). Is the engine oil and coolant clean? No mayonnaise? Will check the coolant now. Engine oil is clean as it is changed very regularly and always comes out clean! Coil pack or something sinister I suspect. How much smoke? Quite a lot of smoke. There's more when revved Link to comment Share on other sites More sharing options...
JackyBoi Posted July 1, 2015 Author Share Posted July 1, 2015 Problem found: Spark plug filled with oil when the HT lead was removed. We think it might be a cam seal which he isn't pleased about! Thanks for the help guys Link to comment Share on other sites More sharing options...
David P Posted July 1, 2015 Share Posted July 1, 2015 Looks more like a poor effort refilling the oil? Link to comment Share on other sites More sharing options...
JackyBoi Posted July 1, 2015 Author Share Posted July 1, 2015 Looks more like a poor effort refilling the oil? No Link to comment Share on other sites More sharing options...
Benjy Posted July 1, 2015 Share Posted July 1, 2015 That won't make it smoke out of its arse though. Link to comment Share on other sites More sharing options...
