DO-Luck V1 - HKS Build Thread
Brazil
I have decided to to make a new Thread 'fresh' start on this 3rd attempt to build my single turbo project.
As you know I recently had a break for parts thread, during the sale of a few items I decided to buy it back having to pay the paypal fee and attempt for the 3rd time to build this car.
I am using a new garage whom already have rebuilt my BMW Convertible engine and did a superb job, and this time all the mechanical work has fix price and guaranteed and final payment wont be made till they have personally put 3k miles on the car o test that everything is good.
As usual every time I choose to rebuild I upgrade the spec list so here it is.
Full Rebuild of HKS T04Z Turbo
HKS Turbo Kit
HKS 264 Cams Exhaust and Inlet side
HKS 87mm Oversize Pistons - 3.1L Upgrade
Carrillo Type Rods with ARP L19 Bolts
ARP H11 Head Stud Kit
ARP Main Stud Kit
Kevlar Timing Belt
And all the OEM bits new like oil pump, water pump oil squirters I have most of this from its previous build.
Head getting Ported and Polished - Flux and air flow tested
Block getting polished so compression is all the same on 6 cylinders.
I have also ordered new wheels custom made to fit over my Endless Big Brake Kit.
Wheels: CCW SP16 Hybrid 'Steped Lip'
Finish: Polished barrel and inner
Bolts: ARP Hybrid Bolts 'Neo Chrome' 'they have a flame burnt effect to it'
Front Wheels: 10j - 19'' - 42+ offset - 2'' Lip
Rear Wheels: 11.5j - 19'' - 50+ offset - 3'' Lip
I plan on using Michelin Pilot Sport Cup SP 2 -- 265 - 30 19 tyres on the front and Toyo R888 305 30 19 at the rear.
I am going to be using my original block but with a sump, crank and modine from a none troubled Facelift NA block supplied by Jurgen - all been checked and been sent to see balance.
The Head has already been machined and is ready for re assemble.
Status of project is Block is with Machine shop and they are boring it out for the HKS Pistons.
Body Shop: Car is going to body shop to work on the arches so there is no rubbing and going to raise the car a bit so even when it squats there is no rubbing - Also going to change my side skirts to Blitz and smooth it as well as the back bumper, Going to Shorten the length of my spoiler by an inch and half and modify my front bumper so the Greddy 4 row FMIC gets more air to it.
Here's the wheels I've ordered.
http://www.ccwheel.com/wheels-displa....php?view=SP16
Car: 2000 built TT6 VVTI with 75k miles
Electric and Fuel System:
Syvecs SP6
Options
1. 1.0 bar - Low boost
2. 1.2 bar
3. 1.5 bar
4. 1.8 bar - High boost
5. Lean cruise/MOT
6. Antilag
7. Anti-theft
8. Valet mode
Toucan Multi Display
HKS 1000cc injectors, twin entry rail, adjustable fpr and braided return hose to connect to stock return line, twin intake fuel pumps, SRD Fuel Cooler.
Turbo Kit:
HKS T04Z
This kit includes HKS' newest Garrett-based turbo. It is a 63T Trim with a 1.00 A/R exhaust housing and the normal T04 style flange. This kit is capable of about 750rwhp and spools quicker than virtually any other kit on the market for the power it makes.
This kit utilizes the famous HKS GT S/S Exhaust Manifold and HKS GT2 Wastegate, the best on the market.
HKS oil cooler and relocation kit
Greddy 4 core FMIC
Nitrous Express Intercooler Cooler.
Koyo Rad
Spark Plugs NGK R7436-9
1 head gasket
Jun Plenum with flow work done
Custom 4'' Exhaust from downpipe back
Billet Water Pump Pulley - Silver
Billet PS Pump Puley - Silver
TRD New Thermostat
Twin Fan Set up
Bonnet damper kit
New OEM Coil Pack, leads/cord, clips
Built Head:
HKS Cams - Exhaust and Inlet
Head fully Ported and Polished - Flux and air tested
ARP Head Stud
Intake kit w\ filter 4"
Drive Train:
V161 Gatrag 6 speed
Big case diff / TRD LSD
Gilken Tripple Plate Carbon Clutch Kit
Brakes:
Endless Complete front and rear 'callipers, disks and pads'. 15'' disks front 13'' rear.
Tyres:
Toyo R888 305/30/19
Toyo R888 265/30/19
ICE:
JL Audio 6.5'' Speakers - Front door pods
Focal PC 165 Speakers - Rear seats pods
Alpine SWR-T12 Shallow mount Sub-woofer
Alpine Amplifier PDX-M6
HID KIT HB3 9003 (8000K)
Bits and pieces:
1) Hose & fittings for header breather to back of car
3) Battery to boot kit + billet battery tray.
4) Toyota Celica Throttle Cable
5) Toyota Head Gasket Kit
7) Aux Belt
8) Billet belt tensioner 'cam belt
9) Air Filter 4'' PnP Hose 'Blue' and Clamp
10) FMIC PS Relocation and alloy catch tank
11) Toyota Idler Wheel for timing belt
12) Boot Rubbers
13) Hose and clamp only - for hard pipe from upper radiator to engine water neck
14) 8 Position Calibration Switch----
15) 4 Bar Mapsensor Kit with plug----
16) 3 Port Boost Solinoid----
17) Bosch Wideband Knock Sensor----
18) EGT Sensor------
19) Supra Loom adaptor----
20) Oil temp sensor-----
21) Oil Pressure Sensor-----
22) NTK Wideband Sensor-----
23) Fuel Pressure Sensor ----
24) Toucan Display -----
25) TRD Engine Mount and Connector ----
26) SRD Twin Fan Kit
27) Greddy Gear Knob
28) New OEM Boot Strut
29) SRD Aux Pulley
30) SRD Fuel Cooler
31) SRD 200amp Alternator
Edited by Brazil (see edit history)
  • Replies 107
Posted Images
Good luck with this build dude, heaven knows you need it!
Good luck Luiz.
Thank you guys; I am really excited to see progress and will be even happier when I hear the car breath again...! The new garage that I am working with are so much easier to deal with, no more bull shit and arrogance from the last shop which just happens to be getting a lot of grieve from unsatisfied customers and have since moved to a smaller shop; ''karma''.
  • 2 weeks later...
Update,
My head is being ported and polished; we are going with the dimple effect' used in aerodynamics; basically what it is, is little dimples like on a golf ball that help laminar air flow over the surface of an object. For example, a golf ball with dimples can travel twice as far as one without.
More info here: http://www.f1technical.net/forum/viewtopic.php?f=5&t=6649
Live link of my head getting worked on.
Looks like a proper job. I wish you the best of luck with it this time round :thumbs:
Thank you for the good luck wish, fingers crossed we will get it this time!
I am waiting for my CCW SP16 Hybrid wheels should be ready to ship from US soon, am ubber excited to see them in person..!
