Common locations of SLD
JayJay1374
Well it needs a speed signal, which means that speed signal wire that runs from your ECU to your dashboard and gearbox has been tapped somewhere. Find an ECU pinout for your car to find the speed signal wire/s, and follow them until you find it. It is most likely to be behind the ECU cover, the dash, the passenger footwell sill trim or the trans. tunnel.
It would be a lot of work to mount it elsewhere, so it is highly unlikely.
