Delboy52 Posted June 25, 2015 Share Posted June 25, 2015 I wondered where the oil was leaking from and I've found where it has collected. I believe it's engine oil from when a hose popped off during a test fit and the rad got a soaking. The lower tray looks to me to be part of the NA Auto radiator as lifting the rad brings the tray along with it. Any suggestions how to drain it out? Quote Link to comment Share on other sites More sharing options...
David P Posted June 25, 2015 Share Posted June 25, 2015 Your first drive will blast that out of there and give your front suspension joints a free oiling. Quote Link to comment Share on other sites More sharing options...
David P Posted June 25, 2015 Share Posted June 25, 2015 (edited) Or stick a bit of that blue cloth into it and leave to sop it up, there's not much there. On the positive side, the oil will have done both the radiator and support panel a great favour. Edited June 25, 2015 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Delboy52 Posted June 25, 2015 Author Share Posted June 25, 2015 Well it's already had a light drive to the mot station and back but it's still brimming. Leaves an oily mess on the floor so I'd prefer to drain it if I can. Also to make sure it is just from the hose spraying it and not something else. Quote Link to comment Share on other sites More sharing options...
David P Posted June 25, 2015 Share Posted June 25, 2015 (edited) Sop it up whilst it's standing about and fit a Soarer oil filter mount, no more worries. Edited June 25, 2015 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Delboy52 Posted June 25, 2015 Author Share Posted June 25, 2015 Might try sucking on a rubber pipe first, then using blue towels. It's properly bathing in that tray. Will get the mount on when I have a filter and filter removal tool. Cheers Quote Link to comment Share on other sites More sharing options...
safcdixon Posted June 26, 2015 Share Posted June 26, 2015 Just jet wash it outa there, then jet your drive when you are finished Quote Link to comment Share on other sites More sharing options...
