Primer sprayed inner rear arches?
binfieldx
It looks as if maybe my insider rear arches have been cut away and re welded, I can see there's some kind of sealant over them and then they've been primer sprayed across in black (you can see the streak of black paint across the white in the picture below), does anyone know why they might have cut away at these inner arches? I'm assuming its to do with when they cut away and welded the wide body arches to the outside but can't understand why they would do the inside? It can't be to do with rust as there isn't a spot of rust anywhere on the car!
