Guest AlanHutchinson Posted June 22, 2015 Share Posted June 22, 2015 As above. My car sounds like a twin turbo hair drier! Can't find any decisive information on how the system works. The reason I am not sure wether it's the clutch itself or not is because it's intermittent - sometimes the fan is pretty tight. Yet sometimes it feels normal. Am I right in thinking there's a solenoid somewhere that controls it? It's a 1jz by the way. If that makes any difference. Thanks. Alan. Link to comment Share on other sites More sharing options...
chrispot Posted June 22, 2015 Share Posted June 22, 2015 here you go as you are online it would have been just as easy for you to search? it should not feel tight when the engine is cold. regards chris Link to comment Share on other sites More sharing options...
Swampy442 Posted June 22, 2015 Share Posted June 22, 2015 OK, hydro fan as in the fan is powered by a hydraulic motor thats part of the water pump? Or a viscous fan? Link to comment Share on other sites More sharing options...
mellonman Posted June 22, 2015 Share Posted June 22, 2015 http://www.mkivsupra.net/vbb/showthread.php?35926-The-sequential-system As for hydro fans the reason you cant find the answer is maybe because your on about a tourque converter which is a fluid coupler? Your first post is lacking a little in decription of your problem for any real help Link to comment Share on other sites More sharing options...
Swampy442 Posted June 22, 2015 Share Posted June 22, 2015 Its a 1JZ, Chasers, Mk IIs etc came with the hydraulic powered fan like the Aristo set up. Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 23, 2015 Share Posted June 23, 2015 (edited) As far as I know it shares and runs off the power steering pump. The PAS pump does little save when manoeuvring, so for whatever reason Toyota / Lexus decided to utilise it to run a small hydraulic motor built into the water pump casting and drive the engine cooling fan with it. A viscous fan drive *MAY* have higher parasitic losses over a hydraulic one, I just don't know, but it was a complex and costly way to go about things, for seemingly marginal reasons. Chrysler tried a hydraulic cooling fan on their sports truck, the Dodge Viper. It lasted one generation and was known to be troublesome. They reverted back to a more conventional system, tail between their legs. I think you can convert a *JZ hydraulic type water pump to conventional and get rid of it and run a viscous fan. Most people have no comprehension how much HP a big cooling fan with the viscous coupling pretty much locked up due to high radiator matrix air temps consumes. They move *FAR FAR* more air then even the biggest electric fans, yet with the viscous slipping as it would on an open road, they draw very little engine power. It remains a mystery to me as to why people are in such a rush to fit (inferior) electric fans... Edited June 23, 2015 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
mellonman Posted June 23, 2015 Share Posted June 23, 2015 Its a 1JZ, Chasers, Mk IIs etc came with the hydraulic powered fan like the Aristo set up. arh harh , my bad I did not even know of such a system . everyday is a school day . I can see chris's point the simplest solousion is often the best Link to comment Share on other sites More sharing options...
garethr Posted June 23, 2015 Share Posted June 23, 2015 I think the benefits can be gauged by the fact that Toyota used it on the V8 Soarer/SC, then dropped it for the Celsior/LS, on the Mk 1 Aristo but not on the Mk4 Supra, and on the Mk3 Supra/early Chaser family, but not on the Soarer/later Chaser. It didn't take them long to realise that the hydraulic motor, associated pipes, and an ECU were just a little over-complicated as a way of blowing air through a radiator... Evidently, it was a solution looking for a problem. Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 23, 2015 Share Posted June 23, 2015 Sucking, not blowing..... Oooh, err matron! Link to comment Share on other sites More sharing options...
garethr Posted June 23, 2015 Share Posted June 23, 2015 You pointed that out just so you could do a Frankie Howerd impression, didn't you. Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 23, 2015 Share Posted June 23, 2015 You're showing your age..... Link to comment Share on other sites More sharing options...
stevie_b Posted June 23, 2015 Share Posted June 23, 2015 Link to comment Share on other sites More sharing options...
Swampy442 Posted June 23, 2015 Share Posted June 23, 2015 I like the hydro fan set up, its pretty clever and the fan is HUGE. But the water pump/hydro pump unit costs around 1200 quid to replace. And yes you can ditch it and fit a standard JZ water pump, thats what Ive done. Problem is the fan shroud Link to comment Share on other sites More sharing options...
