Acton Posted June 19, 2015 Share Posted June 19, 2015 My supra has an aftermarket shifter on it and so a previous owner has wired in this button under the handbrake. On a stock shifter, does the overdrive disengage automatically or is it fully manual operation to switch it on and off? Quote Link to comment Share on other sites More sharing options...
ellis Posted June 19, 2015 Share Posted June 19, 2015 It's a manual operation in as much as you can turn it on or off. Previous owner might just have left it permanently on. Is that button for O/D off/on then? Quote Link to comment Share on other sites More sharing options...
Acton Posted June 19, 2015 Author Share Posted June 19, 2015 It's a manual operation in as much as you can turn it on or off. Previous owner might just have left it permanently on. Is that button for O/D off/on then? Yeah the button turns the O/D on or off. I just wondered whether the stock shifter switched off O/D automatically at certain speed/ revs, as some auto do that. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted June 24, 2015 Share Posted June 24, 2015 I let mine pertinently on all the time. Quote Link to comment Share on other sites More sharing options...
garethr Posted June 25, 2015 Share Posted June 25, 2015 "Overdrive" is just 4th gear. The O/D switch changes from 4th to 3rd and back again. If O/D is on, the gearbox will automatically change into 4th. Quote Link to comment Share on other sites More sharing options...
