cushti Posted June 18, 2015 Share Posted June 18, 2015 (edited) N/A engine, just changing rocker gaskets/plugs e.t.c, & looking down I saw this fuel injector rubber ring dried up & split at the bottom! No fuel leak but perhaps it explains why I can hear what sounds like an induction kit on the wrong side of the engine, doesn't seem to affect the running of the engine strangely, except for a very low idle for an auto (600). I checked the parts cat & just want to be sure what to order (assume Toyota best to buy from for this). Please could someone confirm if what I need is called the 'injector vibration insulator' - 23291-46010? Edited June 18, 2015 by cushti (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 19, 2015 Share Posted June 19, 2015 I have these in stock if you need them, £10.20 plus VAT a set plus P&P Quote Link to comment Share on other sites More sharing options...
cushti Posted June 19, 2015 Author Share Posted June 19, 2015 Hi - thanks for the reply. I might well have to take you up on that but I only need one plus I don't know if I need the 23291-41010 or 23291-46010 as my model is 1993 & the dates cross over on the number I need. Does your set include both types then? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 19, 2015 Share Posted June 19, 2015 I only do them in a set of 6. Quote Link to comment Share on other sites More sharing options...
