D3xt3r Posted September 6, 2005 Share Posted September 6, 2005 I'm currently installing the decat pipe for the first cat direct behind the turbos. The holes dont line up quite nice so I need to drill them out 1-2mm. But when I removed the original cat there is a little sensor plugged there I think its a temp sensor right? What did you have done to it? Should I just kill it away or try to glue him out of the way with some wire holders or something like that? Because there isnt a bung for it on the dp. Quote Link to comment Share on other sites More sharing options...
JohnK Posted September 6, 2005 Share Posted September 6, 2005 I dont remember any sensor in the first cat on mine, not an EGT sensor someone has fitted is it? Quote Link to comment Share on other sites More sharing options...
D3xt3r Posted September 6, 2005 Author Share Posted September 6, 2005 No its definately a stock sensor on there. Its right at the end of the first cat pipe before it goes to the second cat. Quote Link to comment Share on other sites More sharing options...
uk-rich Posted September 6, 2005 Share Posted September 6, 2005 not one on mine when i decatted, i have a uk car if that helps Quote Link to comment Share on other sites More sharing options...
D3xt3r Posted September 6, 2005 Author Share Posted September 6, 2005 Mine is a jspec tt. Quote Link to comment Share on other sites More sharing options...
magicmatty Posted September 6, 2005 Share Posted September 6, 2005 I had one when I did my Jspec NA !! A stock sensor, just before the 1st cat pipe goes into the second pipe - I disconnected it and clipped it up out of harms way and havent had any problems in the weeks since!!! Quote Link to comment Share on other sites More sharing options...
chilli Posted September 6, 2005 Share Posted September 6, 2005 Yeah it's just the cat temp sensor, you won't have the cat, so you won't need the sensor! Just tie it out of the way, dont cut it off!! PS: where did you get the pipe, strange it doesn't line up! Quote Link to comment Share on other sites More sharing options...
D3xt3r Posted September 6, 2005 Author Share Posted September 6, 2005 Got it from a member used. Thats whats crazy. It already was fitted but doesnt fit mine very good. Quote Link to comment Share on other sites More sharing options...
magicmatty Posted September 6, 2005 Share Posted September 6, 2005 Has it got a flexi pipe??? Mine has (Chris Wilson special) and It took me a moment to realise it needed flexing into the right position - tight fit, but ok after a few minutes??? Quote Link to comment Share on other sites More sharing options...
D3xt3r Posted September 6, 2005 Author Share Posted September 6, 2005 Nah straight pipe without any flex. The problem is not the fitment of the pipe the problem is that it doesnt bolt up to the turbo flange above because I cant get it over the studs. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 6, 2005 Share Posted September 6, 2005 Yeah it's just the cat temp sensor, you won't have the cat, so you won't need the sensor! Just tie it out of the way, dont cut it off!! PS: where did you get the pipe, strange it doesn't line up! Yes cat temp sensor just tie it up out of the way. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 6, 2005 Share Posted September 6, 2005 Has it got a flexi pipe??? Mine has (Chris Wilson special) and It took me a moment to realise it needed flexing into the right position - tight fit, but ok after a few minutes??? My N/A first cat removal pipe has a stainless flexi section, as has the stock first N/A cat assembly. None of the turbo de cat pipes I make have flexi pipes as they are nor required. All my pipes are a perfect fit. Sounds like it's NOT one of mine! They are all jig assembled and welded, never, ever, had a single complaint of poor fit. Sensor in first cat on j-Specs is indeed a cat overheat thermocouple, it should be tie wraped up out of the way of the exhaust, and not cut off or disconnected. UK twin turbo models do not have these cat temp sensors, only J-Spec TT's. Quote Link to comment Share on other sites More sharing options...
D3xt3r Posted September 6, 2005 Author Share Posted September 6, 2005 Gonna take a size 15 steel drill to the holes and extend them all 1-2mm and try it again tomorrow. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 6, 2005 Share Posted September 6, 2005 Are you sure you haven't bought a J-Spec 1st cat pipe and are trying to fit it to a UK / US spec car? or vice versa? the flanges are different, as is the pipe angle. Quote Link to comment Share on other sites More sharing options...
D3xt3r Posted September 6, 2005 Author Share Posted September 6, 2005 Seller is 100% sure he has an JSpec TT and I'm 100% sure I have an JSpec TT. Quote Link to comment Share on other sites More sharing options...
chilli Posted September 7, 2005 Share Posted September 7, 2005 Thats really strange that they don't line up then! AFAIK the stud fitting didn't change at all through the years, did it? Maybe the pipe you have is just too tight on the studs and doesn't allow for slight variations, mind you, several mm, thats a lot, doesn't seem right at all. Quote Link to comment Share on other sites More sharing options...
D3xt3r Posted September 7, 2005 Author Share Posted September 7, 2005 Yeah but cant do nothing about it. Dont want to hassle the seller as he didnt remove nor install it on his car so I'm gonna try everything I can to make it fit. Quote Link to comment Share on other sites More sharing options...
chilli Posted September 7, 2005 Share Posted September 7, 2005 Fair play, good luck with it I take it you got the nuts of the studs ok then? I have mine to do soon and I'm worrying over studs snapping lol. Any recommended technique? Quote Link to comment Share on other sites More sharing options...
D3xt3r Posted September 7, 2005 Author Share Posted September 7, 2005 Just sprayed them with some WD-40 and every bolt and nut came of easy with the use of my big ratchet. Tried everything today to this thing aint gonna fit :/ Quote Link to comment Share on other sites More sharing options...
Irvy Posted September 7, 2005 Share Posted September 7, 2005 As the seller of this pipe i have offered toby a refund on the item and am directing this thread to the trader i originally bought the pipe from for some recompense, as when i had my CW pipes fitted recently i was informed a stud was sheared/broken in my manifold from said pipe - i put it down to wear and tear: guess this was the easiest option for the trader to have the pipe fit my car! I remember very clearly the difficulties they had fitting it - didnt realise how much tho! Irvine Quote Link to comment Share on other sites More sharing options...
chilli Posted September 9, 2005 Share Posted September 9, 2005 So maybe it was a uk spec pipe after all? Quote Link to comment Share on other sites More sharing options...
