Prop centre bearing? Need to Bed-in
Jellybean
It's a sealed bearing so not a problem with the copper grease but it shouldn't need bedding in
Cool, will get her on the ramp again and see , it's hard to tell listening as the diff was rebuilt so it maybe something else but when we tested it on the ramp we had no issues...tricky one
Rebuilding a diff is a specialised skill, if it hasn't been shimmed correctly that could be your problem.
Ran her on the ramp and had a screw driver up against her , sounded fine
Maybe the carbonetic diff is just not oem quiet , or maybe it would benefit from a better oil than motul pa90
Thanks David , I was going to run the motul 75w140
https://carbonetic.wordpress.com/tech-support/
They have changed their website, but
I did see on the their the motul pa90 and Paul ran it in the time Attack supra with the same diff
I am just a bit hesitant as its 56 pound versus 20 pound for the motul pa90
I did get the expensive stuff before and made no difference but then again the diff needed a rebuild and it just sounds more like chatter to me but you can hit the sweet spot with her at a certain Rev and no acceleration, she sounds smooth
It's hard to gauge igf this is normal , it's not s common diff people install
But thanks for the help, the expensive oil will be the cheaper option :)
DriveBrand Nameproducts nameViscosity
FRBPX9140S80W-140
FFBPX9118S75W-90
FR/FFNUTECUW7675W-140
FFADVANTAG NEOHi proof shock
FRADVANTAG NEORHD75W-90
FR/MRA.S.H250R85W-140
FF/FRTOTALPRO-R75W-140
Welcome. :D
I don't understand why that should be so, it's an open group?
Here's a better pic that's in the Transmission Group here with info. http://www.mkivsupra.net/vbb/group.php?discussionid=132&do=discuss
I found and linked a copy from my album which should work in open forum, this is the same as your prop and shows how they go together.
Just came up with a message to say I need to "click here" to join to see the content
Thanks again, thats great ! Will get her on the ramp tomorrow and check her out , hopefully a simple fix
I was testing again today, I can get a sweet spot at 60 km/hr ; no noise; something is out of balance
Well if you find you need to re-phase the driveshaft and it is still vibrating don't forget to turn one half exactly 180° and try it again.
Thanks Damien
Oh yeah I got the door gromets off Toyota for free, considering I bought so much off them lol
