Dim Sum Posted June 15, 2015 Share Posted June 15, 2015 I currently planning to relocate the power steering bottle and I notice the 2JZ GE is mounted above the pump. http://www.supra-forum.com/typo3temp/pics/2jgzevvti_01_4c3d44ed06.jpg My engine is the 2JZ GTE and I was wondering is that possible to mount it there? Is it just a bracket that on the GE engine that's holding the bottle and can the same bracket be used on the GTE engine? Quote Link to comment Share on other sites More sharing options...
Clausz Posted June 15, 2015 Share Posted June 15, 2015 Indeed. The GE bottle can easily be used on a GTE pump. Do you have some sort of aftermarket intake on your GTE, else it won't fit. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted June 15, 2015 Author Share Posted June 15, 2015 Indeed. The GE bottle can easily be used on a GTE pump. Do you have some sort of aftermarket intake on your GTE, else it won't fit. Yes, I ve fitted a aftermarket inlet so I need to relocate the bottle but I quite like the GE's bottle location. So its not a bracket? I will need a GE power steering bottle for me to mount it there? Quote Link to comment Share on other sites More sharing options...
Steve Posted June 15, 2015 Share Posted June 15, 2015 Yes you will need the whole N/A reservoir, its not just a bracket. I used one of these on mine Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted June 15, 2015 Author Share Posted June 15, 2015 Yes you will need the whole N/A reservoir, its not just a bracket. I used one of these on mine Thanks Steve for the confirmation. So the hunt is on for a N/A reservoir Quote Link to comment Share on other sites More sharing options...
