harryww89 Posted July 28, 2015 Author Share Posted July 28, 2015 I took the Supra out last night for a few pulls and took note of the detail. Length of running now doesn't effect the problem - Straight away from initial running the hesitation is present above 5000rpm (Obviously warmed up to minimal operating temps). Engine Management/Check engine light comes on as soon as the affected load site is reached. Fuel Pressure is a healthy 3.5bar throughout WOT above 5000rpm - The needle does seem to jump bounce around from 3.4-3.6 when in the effected area. Again Oil pressure is a healthy 7bar on WOT. I'm struggling to find an igniter at the minute. As a precaution, I have bought a new set of coilpack Clips - The currents all look in good condition, but it's just another factor to cross of the list, these should arrive today and I'll install them this evening and try again. Link to comment Share on other sites More sharing options...
Sukhy Posted July 28, 2015 Share Posted July 28, 2015 Be interesting to find out what the issue is mate. Keep the updates coming and good luck with it. Link to comment Share on other sites More sharing options...
T2 MSW Posted July 28, 2015 Share Posted July 28, 2015 Im in Stockport and happy to lend you my ignitor off my car to test with. I know how frustrating it is trying to resolve this sort of thing on your own. Link to comment Share on other sites More sharing options...
harryww89 Posted July 29, 2015 Author Share Posted July 29, 2015 Hi, I'm actually heading to Manchester on Saturday, I just wasn't intending to take the Supra. Hoping the coilpack clips are here tonight - Should these not fix the problem, I may take you up on the offer, i'll keep you posted! Link to comment Share on other sites More sharing options...
harryww89 Posted July 29, 2015 Author Share Posted July 29, 2015 Surprise surprise, coilpack clips made no difference. Going to resort to taking it down to TDI international. Link to comment Share on other sites More sharing options...
T2 MSW Posted July 29, 2015 Share Posted July 29, 2015 If your passing manchester Sat pop round and we can take a look. Swap the ignitor over. Link to comment Share on other sites More sharing options...
harryww89 Posted August 13, 2015 Author Share Posted August 13, 2015 Hi All, I have finally found the problem with misfire - All of the symptoms came together last night as I was setting off to leave for the Nurburgring and ended up with a 5 hour limp to drive 60miles back home. Basically, the issue with the vehicle only misifiring when 'warm' was down to the fuel pump. There is an external Aeromotive A1000 fuel pump in the boot, to which yesterday, I believe the heat from the car being sat in the sun all day finally sent it over the edge, The fuel pump would not prime, only upon cooling the pump down with water/ice pack would the car start and run very poorly, reading up on this thing, I believe the adhesive on the magnets on the pump can fail? Eitherway, I believe this was the source of the issue - I'm unsure now as to what replacement to go for? Another A1000 or amend the set up to run twin bosch 044's? Are there any other fuel pumps on the Market that can support 700bhp that people would recommend? Many thanks. Harry Link to comment Share on other sites More sharing options...
Paul Whiffin Posted August 13, 2015 Share Posted August 13, 2015 Walbro 450lph pump will do it just about or 2 if you want some headroom. Link to comment Share on other sites More sharing options...
harryww89 Posted August 13, 2015 Author Share Posted August 13, 2015 Walbro 450lph pump will do it just about or 2 if you want some headroom. Hi Paul, Would this be an Intank pump? Here is a picutre of the set up - Ideally i'd like to keep the same fittings and swirl pot system - Just replace the A1000 With something else, whether this be 2 external pumps or another large single. Cheers, Link to comment Share on other sites More sharing options...
Paul Whiffin Posted August 13, 2015 Share Posted August 13, 2015 Hi Paul, Would this be an Intank pump? Here is a picutre of the set up - Ideally i'd like to keep the same fittings and swirl pot system - Just replace the A1000 With something else, whether this be 2 external pumps or another large single. http://img.photobucket.com/albums/v471/vfs72/IMG_8086_zpsadpj6okn.jpg Cheers, Replace it with another Aeromotive for easy of installation and no remap required then either? I bet thats noisy sitting in the back of the car like that! Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 13, 2015 Share Posted August 13, 2015 (edited) Are you using the stock pump in the tank as the lift pump? I find the Bosch pumps the most reliable units on the market, so always go for the 044. I am not sure I would fancy having no firewall between myself and that swirl pot and plumbing. In a competitive environment the scrutineers would send you packing. Seen the Oz pick up truck photos posted on the forum earlier.... ? My thoughts are, is there a chance the huge main pump is slowly heating the fuel to vapour point? Was the problem evident with a low fuel load in the main tank? I don't like running main pumps any bigger than needed due to fuel heating. If this *IS* your problem you could use a cooler in the return line (*NEVER* in the pressure line. Running a DC pump slower can sometimes helps, but occasionally a pump will run the fuel hotter at a lower than design RPM. Edited August 13, 2015 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
harryww89 Posted August 13, 2015 Author Share Posted August 13, 2015 It's ridiculously loud in the back Paul - Truly deafening. Chris, thanks for your input, will drop you an email. Link to comment Share on other sites More sharing options...
Sukhy Posted August 13, 2015 Share Posted August 13, 2015 I'm running a bosch 044 fuel pump at the moment at BPU and it is pretty noisy. However, I am getting the same issue as harryww89 where the car holds back slightly on the 2nd turbo when warm (first 20mins driving it is fine) and thought it may be the pump also. It has been in there around 5 years now but as Chris mentions, they are reliable so I'm now thinking it may not be the pump. Link to comment Share on other sites More sharing options...
harryww89 Posted September 25, 2015 Author Share Posted September 25, 2015 (edited) Hi Chaps, For anybody who's interested, it turned out to be the in tank pump which was the failure, it was not even a Supra pump in tank, Turned out to be a Skyline pump in there:blink:! I re-plummed the system to run on the Skyline pump, and the car wouldn't start due to extremely poor fuel pressure. I believe the engine is still in one piece thanks to the Aeromotive and swirl pot and pressure gradually losing instead of completely shutting off. Anyway, new Walbro 450lph fitted, car started first time after being stood for 6 weeks and runs well, although I have yet to take it on a long run, off to Torque Developments Next week for some tinkering so we will see how we go! Edited September 25, 2015 by harryww89 (see edit history) Link to comment Share on other sites More sharing options...
Style Posted September 25, 2015 Share Posted September 25, 2015 Glad you got it sorted in the end and thanks for bringing the thread to a conclusion Always good when you're troubleshooting and get an answer after reading for pages! Link to comment Share on other sites More sharing options...
