Mike2JZ Posted June 12, 2015 Share Posted June 12, 2015 Looking to move soon, so would rather some of these items find a new home rather than the trash. All parts can be collected from Canterbury, brought up to monthly Bluewater meets or posted out. Pictures to be uploaded later tonight Rear Subframe - £120 Bit dusty from sitting in workshop for a while Bushes are in good condition & comes with 1 LSD mount. Frame painted dark blue 2JZGE - £200 The engine has been taken apart, cleaned, painted in gloss black and put back together. Engine comes with a new timing belt, manual ECU, full engine wire loom, all bolts that haven't already been installed, gaskets, vaccum hoses, vsv, fuel rail + injectors, lower part of inlet manifold & distributor. A few parts needed to complete the engine are required: - New Distributor Cap + Rotor - New Fuel Filter - Bottom sump gasket - Rocker cover gaskets Rear Wishbone - £30 Good Condition, joint & bushings have no damage Rear Suspension Arm no.2 (RH) - £5 Joint has seen better days Pre Facelift Driverside Belt *1 remaining - £5/e (1 set sold to marcdixon) Pre Facelift Passenger Belt * 1 remaining - £5/e (1 set sold to marcdixon) Used, passed MOT Pre Facelift Rear Seatbelts - £10 Used, passed MOT Rear Seat Buckles - £10 Greddy Cam Cover - £15 Modified to fit N/A, will still fit TT Passengerside Pre Facelift Front Wing + Veilside Arch [white] - £15 Set of wiper arms + blades - £15 Scratch on one wiper blade Boot Light - £5 Veilside Spoiler (white) with carbon blade - £10 Top half of carbon blade needs a refurb N/A Manual ECU - £50 Pre Facelift Digital Clock - £35 AVS VS5 18" 8.5j Rims *2 - £100 Link to comment Share on other sites More sharing options...
uzzyuzzy Posted June 12, 2015 Share Posted June 12, 2015 Am I reading this right an engine for 200? Link to comment Share on other sites More sharing options...
safcdixon Posted June 12, 2015 Share Posted June 12, 2015 il take the pair of front seat belts please, with postage to durham pm me the cost Link to comment Share on other sites More sharing options...
trebor69 Posted June 12, 2015 Share Posted June 12, 2015 Post deleted. Link to comment Share on other sites More sharing options...
MadMax2042 Posted June 12, 2015 Share Posted June 12, 2015 I'll take the rear wing but can't pick up for a few weeks if that's cool. If anyone can pick up and store for me/pass on to members that are traveling north would be appreciated too Link to comment Share on other sites More sharing options...
K22SUP Posted June 12, 2015 Share Posted June 12, 2015 I will take cam cover if no damaged by modification Link to comment Share on other sites More sharing options...
Mike2JZ Posted June 12, 2015 Author Share Posted June 12, 2015 il take the pair of front seat belts please, with postage to durham pm me the cost Pm'd & Sold I'll take the rear wing but can't pick up for a few weeks if that's cool. If anyone can pick up and store for me/pass on to members that are traveling north would be appreciated too Hi Max, that's fine, I'll pm you my payment details and we can sort out the best way to get it to you, I don't mind dropping it off with another member if it's not to far. I will take cam cover if no damaged by modification Hi Edward, I'll upload some pictures of the cover later tonight when I get home, but there is no damage, the rear of the cover has just had a few mm shaved off in order for the cover to fit around the N/A engine loom that sits near the cams, but you can't see this when it is fitted. Link to comment Share on other sites More sharing options...
Mike2JZ Posted June 13, 2015 Author Share Posted June 13, 2015 First post updated with photos now Link to comment Share on other sites More sharing options...
Supraleeturbo Posted June 13, 2015 Share Posted June 13, 2015 Mike if you want to drop madmax wing of to me as I'm going to see him in a few weeks Link to comment Share on other sites More sharing options...
walkerstrider Posted June 13, 2015 Share Posted June 13, 2015 Would you post the rear subframe? Link to comment Share on other sites More sharing options...
Guest Wishbone Posted October 1, 2015 Share Posted October 1, 2015 Hi Do you still have the wishbone, left hand side upper, and is the bushing OK Can you post to Dublion, Thanks Pete Looking to move soon, so would rather some of these items find a new home rather than the trash. All parts can be collected from Canterbury, brought up to monthly Bluewater meets or posted out. Pictures to be uploaded later tonight Rear Subframe - £120 Bit dusty from sitting in workshop for a while http://i.imgur.com/rs1AEYWh.jpg http://i.imgur.com/k6A8zYMh.jpg Bushes are in good condition & comes with 1 LSD mount. Frame painted dark blue 2JZGE - £200 http://i.imgur.com/GSUgp9Ph.jpg http://i.imgur.com/KfrJ8ewh.jpg The engine has been taken apart, cleaned, painted in gloss black and put back together. Engine comes with a new timing belt, manual ECU, full engine wire loom, all bolts that haven't already been installed, gaskets, vaccum hoses, vsv, fuel rail + injectors, lower part of inlet manifold & distributor. A few parts needed to complete the engine are required: - New Distributor Cap + Rotor - New Fuel Filter - Bottom sump gasket - Rocker cover gaskets Rear Wishbone - £30 http://i.imgur.com/Drrg7eQh.jpg Good Condition, joint & bushings have no damage Rear Suspension Arm no.2 (RH) - £5 http://i.imgur.com/ObyuXWjh.jpg Joint has seen better days Pre Facelift Driverside Belt *1 remaining - £5/e (1 set sold to marcdixon) Pre Facelift Passenger Belt * 1 remaining - £5/e (1 set sold to marcdixon)http://i.imgur.com/GA0gOXe.jpg Used, passed MOT Pre Facelift Rear Seatbelts - £10 http://i.imgur.com/EaKcf4V.jpg Used, passed MOT Rear Seat Buckles - £10 http://i.imgur.com/qCSduel.jpg Greddy Cam Cover - £15 http://i.imgur.com/jrLTEG9.jpg?1 http://i.imgur.com/tGjy3Ez.jpg Modified to fit N/A, will still fit TT Passengerside Pre Facelift Front Wing + Veilside Arch [white] - £15 Set of wiper arms + blades - £15 http://i.imgur.com/DHsULW7.jpg Scratch on one wiper blade Boot Light - £5 http://i.imgur.com/Iw8ypfI.jpg Veilside Spoiler (white) with carbon blade - £10 Top half of carbon blade needs a refurb N/A Manual ECU - £50 Pre Facelift Digital Clock - £35 AVS VS5 18" 8.5j Rims *2 - £100 Link to comment Share on other sites More sharing options...
Mike2JZ Posted October 1, 2015 Author Share Posted October 1, 2015 Hi Do you still have the wishbone, left hand side upper, and is the bushing OK Can you post to Dublion, Thanks Pete I believe I still have it, I will next be in the workshop on Monday morning so will take a look and get back to you. Link to comment Share on other sites More sharing options...
