Blanking plug for aerial hole
Lee_e
Theres loads on ebay, the plastic cap type which has a plastic nut on the back, add a bit of sealant between and it wont leak i used one on my old supra for nearly a year
I have one to go on my current one now
You can get the rubber grommets but someone can easily push it in :thumbs:
How hard is it to fit Noz? Surely it's just remove sock antenna then slip in blank plug?
Berg: I think your thinking of the rear wiper delete bungs . The antenna hole is angled and curved so it's harder to fill with a standard rubber/ plastic bung.
  • 6 months later...
I have a load of these to sell.
I'll be back in the UK in 2 weeks, I'll post a photo later on tonight if you like.
Noz, do you have any of these left?
My stock aerial just popped out the top so I had to remove it, I have the hole covered by insulating tape at the moment but looks rubbish.
Regards,
Rich
Sold out. But I'm sure you could make your own, or use a cheap plastic bung (which look's utter bollocks).
Sadly, unless I start making these myself I can't see me getting anymore. And you can't import them anymore either as my supplier stopped using PayPal.
