Guest gerryh09 Posted June 4, 2015 Share Posted June 4, 2015 Hey Iv a 95 NA supra when started it revs to 2000 and as it warms dyes bact to 1500 and stays there it should be way lower than this i cleaned the Throttle body could it be the Idel control sensor any help would be great Thanks Quote Link to comment Share on other sites More sharing options...
Yarco Posted June 4, 2015 Share Posted June 4, 2015 Typical problem on Supra's is the idle control valve. Cost over a grand to get replaced so most people don't bother, my car idled as low as 400rpm once warm. Quote Link to comment Share on other sites More sharing options...
That_Supra_Guy Posted June 4, 2015 Share Posted June 4, 2015 I would double check the cable tension on the throttle cable, can't remember if there is an idle adjust screw or not either. Anyways, you can clean the IACV, I had to when my idle was all over the place, worked a charm. Just search it. Quote Link to comment Share on other sites More sharing options...
Guest gerryh09 Posted June 4, 2015 Share Posted June 4, 2015 I would double check the cable tension on the throttle cable, can't remember if there is an idle adjust screw or not either. Anyways, you can clean the IACV, I had to when my idle was all over the place, worked a charm. Just search it. Ye the tension on the cable is ok so il just give the IACV a clean and hopefully that works Thanks Quote Link to comment Share on other sites More sharing options...
