Removing air con
Paul-90
You will also need to either remove the front plate from the AC compressor to support the PS pump, or make a bracket up to do the job. If you don't, you risk wrecking your block. The AC compressor also provides vital support to the PS pump.
Here you are:http://www.mkivsupra.net/vbb/showthread.php?320520-Air-con-delete-bracket&highlight=power+steering
Edited by Shane (see edit history)
  • 3 weeks later...
