vsv + vacum leak
jza800
ok, i dont now if i did something wrong or what happend.. when i did test for pressure the car was in ttc mode, so both vsv was not connectet to the pressure line, now i did mount both vsv to the lines again as stock, now i cant get any pressure on the line again.. but if i take that hose off that goes from the lines to the iacv vsv, and block it with your hands i can get pressure to the system again... does that sound right, or do i have a bad iacv vsv? or do i use the wrong line to pressure testing??
Edited by jza800 (see edit history)
With EVERYTHING in the sequential setup as Toyota intended it should hold boost pressure for a while, with audible leaks. Stop messing with the TTC junk, you cannot test like that. Even if the VSV's are seemingly OK they are in need of changing on the basis of age alone, in my opinion.
I Did find my mistake, had the wrong hose on the wrong pin on the vsv so now i can get pressure to the system. Had 20 psi before i got to bed, this morning i had 12 psi back in the system 7 houres later.. so guss that it dont have more leak than that is ok, so next is vsv check
and now it all works again. did check all vsv, all within spec and working ordre execcpt on.. had another on laying around... put everthing back, and now it boost as it should.. 0.6 bar on the first, and 0.8 - 0.9 on the second..
