Check if UK turbos
Timlowthian
Hi all just wondering if there is a way you can check to see if an engine has UK turbos?
Reason I ask is have just fitted a TT engine to my na which I presumed was a j spec because of the ECU. However after going to fit the decat I have it would appear to be far too small.
Am I right in thinking the UK spec uses a larger diameter decat?
you can see it on the turbo.. if it is boltet to the manifold with 4 bolts = eu spec 3 bolts= j-spec
does i have a maf sensor= eu spec if only map sensor = j-spec
does i have a resister box in the intake side = eu spec if only igniter box =j-spec
if it have the raised bump in left side on the top off the intake manifold = eu spec if the rasied bump is is the middel off the intake = j-spec
if the engine have egr valves on the back off the intake = eu spec if not= j-spec
or post a picture off the engine
