Swampy442 Posted May 27, 2015 Share Posted May 27, 2015 Just fired my engine up for the first time in 'a while'... Need to leak check it, check the auto box operation etc. How long can you safely run the engine, a minute? 30 seconds? 5 minutes? Quote Link to comment Share on other sites More sharing options...
bignum Posted May 27, 2015 Share Posted May 27, 2015 A minute is normally ok, however last time i did this my waterpump started to leak right after. Quote Link to comment Share on other sites More sharing options...
Richie_k83 Posted May 31, 2015 Share Posted May 31, 2015 The Engines Oil acts as a coolant. However, i wouldn't run it more than a minute tops personally. Quote Link to comment Share on other sites More sharing options...
Pete Posted May 31, 2015 Share Posted May 31, 2015 Good question, let's do some science to find out. Start it up and time how long it takes before it smokes, then explodes and belches fluids everywhere and we'll have the answer to your question. Don't forget to video it for the archives. Quote Link to comment Share on other sites More sharing options...
Havard Posted May 31, 2015 Share Posted May 31, 2015 This will not be good for the water pump. Lubrication is everything, just like the ladies. Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted May 31, 2015 Share Posted May 31, 2015 To put it scientifically, no longer than the distance from your old place on Whisby Road to the Mazda garage just after Sainsburys. That's how long it took mine last time when that coolant hose failed to kick up a steam and splutter and almost shat itself. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 31, 2015 Author Share Posted May 31, 2015 Thanks for your help, but I put the hoses on and hooked the rad after the initial start up. Quote Link to comment Share on other sites More sharing options...
Pete Posted May 31, 2015 Share Posted May 31, 2015 Thanks for your help, but I put the hoses on and hooked the rad after the initial start up. Much more sensible! Quote Link to comment Share on other sites More sharing options...
