Cam timing adjustable pulleys
K22SUP
Hi guys car has Hks 264 cams and adjustable pulleys and I have just found out from previous owner it didn't start hesitating till he done the belt so I am looking for best way to set the whole lot up again as far as I see it's quite a big job and we need template that bolts to crank ect anyone got one ? Or done this
You don't need one on the 2JZ - set the pulleys to zero adjustment, and there should be a dimple on them that you line up with a notch on the top of the metal backing plate behind where they sit. This is with the engine at TDC.
Set them to zero and the car will run and won't hesitate if the problem at the moment is the cam timing being off. Once that's sorted, then you can tweak the cam timing with the adjustment to help get a better idle and so forth :)
You need a dial test indicator, magnetic stand, extended finger for the DTI, and to make a ferrous plate to mount the DTI stand to, on the head. Plus a twin cam is possibly not the easiest engine to learn cam timing on. Get a pro to do it unless you like headaches :)
If you just set it up with the adjusters set to "0" and line up the dots the engine will be fine, getting it spot on will probably make an unnoticeable difference.
