P_Bazz Posted May 25, 2015 Share Posted May 25, 2015 Maybe there is someone on here who can shed a little light on this unusual problem. I bought an almost complete facelift SZR 6 speed clutch for the NA-AT to TT6 swap that I'm doing for a friend. Only the throwout bearing assembly in the pressure plate was missing. Now that said friend found another lightly used pressure plate WITH the bearing assembly still on it, only after installing the gearbox and engine back into the car I received word that the pressure plate was from a TT and not a SZR. I checked the Toyota systems and the part numbers don't match between the two:(. However they looked quite the same and the TT pressure plate fitted to the SZR flywheel fine. My question being; will it still work with this setup or do I have to take it all out again? Facelift SZR friction disc 31250-14200 (currently in the car) Facelift SZR pressure plate 31210-14180 TT friction disc 31250-14190 TT pressure plate 31210-14170 (currently in the car) Quote Link to comment Share on other sites More sharing options...
