engine warning light post boost controller install
Dave Carroll
Completed my boost controller install today and initial setup targeting 1.2bar.
only issue is I have the engine management light on, and it wasnt before.
I have plumbed in the ebc as the advice elsewhere on the forum and the ebc manual says, and it is running perfectly - no issues with the actual driving itself.
I havent read any fault codes yet but I assume this is down the the standard vsv being bypassed?
should I expect this warning light?
info on the car:
-hks evc6 boost controller
-bpu supra running 0.9bar previous to this install, now roughly 1.2bar. Usual mods for bpu
it makes sense to me that the car wouldnt like the bypass of the vsv but want to check for advice.
maybe I can unplug the vsv so I can still have that warning light tell me of real issues??
Cheers
dave
it is not the vsv fault that the engine light is on, so maybe under install you have lost some connection on some plugs down there.. but as it is easy to read the ecu codes out, that would be the first thing i woud do, as you then now where to look..
So read the fault codes, only 1: 42
as I understand, code 42 is the no1 speed sensor circuit, which happens to be one of the pinouts I had to tap into for the ebc.
I assume it isnt expected to throw this fault using the evc6 on the supra when tapping into the speed circuit? Or maybe it is advised to tap into the tac line instead?
From everything I have read on the EBC, it appears it is necessary to connect it to the TPS pinot and either the speed or rev signal pinot of the ECU to work correctly.
However, the manual of course only states to connect it, not whether it is strictly necessary or not, and I do not profess to be an expert on this.
I haven't tried without it connected, but when I first installed, and had connected the EBC to what I thought was the speed signal pinot (it wasn't...) the car would not even start. As soon as I connected to the correct pinot, it ran like a dream.
Perhaps a shout to Paul Whiffin who I am sure has installed a few of these can shed some experience on this particular EBC?
