Rust issues
Paul-90
Hi
i started stripping off the hockey sticks etc on my car ready to be re undersealed. Upon removing them i found this.
Now the car is away to my mechanic to get welded and undersealed along with all new brakes lines and braided lines. Now my question is is this a normal area for rust and will simply patching it sort it or is it going to just keep coming back?
With cheap endoscope type USB cameras all over Ebay you might want to frighten yourself with a look in side those box sections. Then again, you might be better not knowing ;) Without an endoscope type camera one might neatly enlarge the hole and have a good look inside with a bright torch.
Worrying Chris. You must see the problems more than most. My old NA had rust problems but after being in Scotland as a daily driver, it was no surprise. My TT as a fresh import had none whatsoever, which was nice.
H.
For the age of all our cars they really haven't faired too bad escpecially if you look at how many much newer cars are rusting out these days especially vans. I drive an 11 plate transit for work and it has rust on every panel my supra is a 93 and all I've found is a small bit on the tailgate which can just be swapped out so they've deffinatly done something right when they made these old Toyotas :thumbs:
In the same way you would use waxoil on the section as David said
seam sealers that i have used are a thick type of paste, I didn't know there was a thin type that could go down a 1/4" tube and be sprayed, or do you mean just on the beam under the radiator?
Thanks for the replies guys. Mechanic has it all striped down on the ramp and the holes havent really got any bigger. Welder is looking at it this week. As for the radiator area it is all perfect. Those holes are the only bits of rust on the whole car so probably cant complain. Sill are getting filled with waxoil as well after all the welding is getting done. The thing is i would never have found these holes as they were covered.
Whilst removing the under tray, I noticed rotten loose pieces of metal falling out from beneath the rad area which I guess is the support panel? Is this difficult to repair?
Depends how you want to do it, you can just cut out the rotten section and fabricate your own
to replace it or you can buy the support member from Toyota and replace it completely which
is what i did on my car
