coza Posted May 20, 2015 Share Posted May 20, 2015 Hi got a weird problem that's started happening, First of all I've got a jspec twin turbo 6 speed running 0.9 bar max boost When accelerating just as the 2nd turbos about to kick in the car looses boost and just runs at .5 so accelerating but not sharp as it should, but if I'm in 5th or 6th gear sometimes it kicks in sometimes it doesn't Anybody got any ideas ... What to check ? Cheers Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted May 20, 2015 Share Posted May 20, 2015 Check that the IACV VSV is functioning as it should, there is a write up on here all about the sequential turbo system and all about the issues that often come with. There will be an explanation which I'm sure would help you. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 21, 2015 Share Posted May 21, 2015 Yes, check, or ideally renew the VSV's. They are all very old now, and do not last forever. Also check for pressure / vacuum leaks on all small hoses. If you have that blue none braided silicone *$#~@ as hoses, you are asking for trouble. Even more so when it's having to be held on with little tye wraps. You wouldn't have sex with a stranger using an Ebay condom held on with a tye wrap now, would you? Quote Link to comment Share on other sites More sharing options...
coza Posted May 25, 2015 Author Share Posted May 25, 2015 This actuator was stiff to move is this right ? Quote Link to comment Share on other sites More sharing options...
coza Posted May 27, 2015 Author Share Posted May 27, 2015 Can u replace the actuator on jspec turbos or do you have to change the whole turbo unit ? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 27, 2015 Share Posted May 27, 2015 Yes, they just unbolt on a bracket Quote Link to comment Share on other sites More sharing options...
BOB B Posted May 27, 2015 Share Posted May 27, 2015 [ATTACH=CONFIG]201745[/ATTACH] This actuator was stiff to move is this right ? Thats your Exhaust Gas Control Valve, yes it is quite hard to move but you should be able to. Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted May 27, 2015 Share Posted May 27, 2015 Have a look at this thread: http://www.mkivsupra.net/vbb/showthread.php?27904-Sequential-turbo-problems Quote Link to comment Share on other sites More sharing options...
