Chris Wilson Posted May 26, 2015 Share Posted May 26, 2015 idle valve won't cause the hesitance. TPS could do. Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 26, 2015 Author Share Posted May 26, 2015 idle valve won't cause the hesitance. TPS could do. Thanks, the link i attach on the plugs it that the right ones? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 26, 2015 Share Posted May 26, 2015 it is this plugs right?? http://www.ebay.co.uk/itm/6x-NGK-Platinum-Spark-Plug-PFR7B-4853-/221028609225?pt=LH_DefaultDomain_3&hash=item337654ecc9 Yes, I have used these extensively on de catted 2JZ-GTE units Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 26, 2015 Author Share Posted May 26, 2015 Thanks i have bourght Them now and waiting Them to arrive. I dont have to gab then or anything just mount Them in the engine? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 26, 2015 Share Posted May 26, 2015 They should be ready to fit. Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 26, 2015 Author Share Posted May 26, 2015 (edited) have now taken the plugs and coil pack out off the car.. and this is how i looks... first 2 picture is the coil pack on cyl 3 and 4, both have those cracks.. picture 3: cyl 1 and 2 picture 4: cyl 3 and 4 picture 5: cyl 5 and 6 and on the first coil pack, i could see the pin on the connecter not where all the way it.. Edited May 26, 2015 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 26, 2015 Share Posted May 26, 2015 Replace the cracked coils, for sure. Ideally buy a new set of coils. Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 26, 2015 Author Share Posted May 26, 2015 i have ohm the coils, and they are 0.7 to 0.8 ohm cold.. so they are within spec.. i will trye my local deeler and see what he can get new for.. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 26, 2015 Share Posted May 26, 2015 The fact they are cracked may mean the HT is escaping and tracking to ground under load. They DEFINITELY should be changed!! Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 26, 2015 Author Share Posted May 26, 2015 can i use some off those coil packs, as i think they are cheper that going to toyota ?? http://www.ebay.co.uk/sch/i.html?_odkw=coil+pack+2jzgte&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR6.TRC1.A0.H0.Xcoil+pack+supra.TRS0&_nkw=coil+pack+supra&_sacat=0 Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 26, 2015 Author Share Posted May 26, 2015 but there is one ? i dont have gotten any answer on: When the engine light is off, the engine hesitating those 2 times from between 3500rpm to 4500 rpm , all over those rpm range NO hesitating.. i can go full trottle from 1st and up with no hesitating.. i have only notice the hesitating sometimes in 2nd gear and full trottle, but always in 3rd gear at full trottle.. and ONLY those 2 times and between 3500 rpm to 4500 rpm. from 4500 til stock redline at 6500 rpm i cant feel the hesitating, so i dont think it is doing it there.. And i can see on the air/fuel gauge that under hesitating it goes lean but maxium 2 sek, then it goes right to rich.. When the engine light is ON there is no hesitating what so ever, and pull strong and normal... And here is the air/fuel gauge reading normal, direct to rich under full trottle and the car goes to boost.. So what does the ecu change when the engine light turn on? does it change fuel ignition spark fuel or what does it do, since that there is no problem there??? i really hope you will take your time to answer that, if you can, or direct someone in here, that could have that answer, as it would help me alot to undestand Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 26, 2015 Share Posted May 26, 2015 I do not know why it is doing this. If I had the car here I could work it out, but without "hands on" it's very hard to guess. Very odd fault!! Reading lean does NOT NOT NOT always mean it IS lean, it do this if it goes very rich due to missing sparks.... - - - Updated - - - can i use some off those coil packs, as i think they are cheper that going to toyota ?? http://www.ebay.co.uk/sch/i.html?_odkw=coil+pack+2jzgte&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR6.TRC1.A0.H0.Xcoil+pack+supra.TRS0&_nkw=coil+pack+supra&_sacat=0 I have always used genuine coils, I have never tried any of those, sorry. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 26, 2015 Share Posted May 26, 2015 OEM all day long. I killed 2 sets of aftermarked within 4000mls. Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 26, 2015 Author Share Posted May 26, 2015 can you then say what they cost overthere Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 26, 2015 Author Share Posted May 26, 2015 I do not know why it is doing this. If I had the car here I could work it out, but without "hands on" it's very hard to guess. Very odd fault!! Reading lean does NOT NOT NOT always mean it IS lean, it do this if it goes very rich due to missing sparks.... - - - Updated - - - I have always used genuine coils, I have never tried any of those, sorry. ok, then it is a hard time to locate the problem.. i will trie first to change the plugs, and reuse the stock coil (i now you think that i stupid, but again that depends off the cost.) then if it work, i will save up to new coil packs for sure.. so dont hate me Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 26, 2015 Author Share Posted May 26, 2015 (edited) if the tps not are 100% calibratet would that give a error code? i dont get the tps error code.. only 42 speed sensor, as i always had.. Edited May 26, 2015 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted May 26, 2015 Share Posted May 26, 2015 Just jumping in on the end of this so sorry if already said Check battery terminals are nice and tight Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 26, 2015 Author Share Posted May 26, 2015 Just jumping in on the end of this so sorry if already said Check battery terminals are nice and tight your more then velcome to jumping in, you could have some answer we other have overseen but the battery terminals are nice and tight.. and battery is new have also taken the compression test, witch is (170 psi/12 bar) on all 6 cylinders, so then we now that there is no problem with piston or valve.. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted May 26, 2015 Share Posted May 26, 2015 Ok Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 26, 2015 Share Posted May 26, 2015 can you then say what they cost overthere I get all my parts from SRD Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 27, 2015 Author Share Posted May 27, 2015 I now got a hold in my local toyota deeler 800 punds overhere for 6 coil packs, can that really be true? If someone have some experince with aftermaked coils please share you mind Quote Link to comment Share on other sites More sharing options...
Wez Posted May 27, 2015 Share Posted May 27, 2015 (edited) I now got a hold in my local toyota deeler 800 punds overhere for 6 coil packs, can that really be true? If someone have some experince with aftermaked coils please share you mind http://www.garagewhifbitz.co.uk/toyota/supra/ignition-parts.html/garage-whifbitz-568.html http://www.superspark.com.au/producttoyota.htm Edited May 27, 2015 by Wez (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted May 27, 2015 Share Posted May 27, 2015 Denso make the OE parts for Toyota, it should work out cheaper buying direct from Denso in the US http://densoautoparts.com/find-my-part/vehicle-selection Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 27, 2015 Author Share Posted May 27, 2015 (edited) i have now tried this on the spark plugs: i have done mine on ohm 20k 2x 5.5 ohm 1x 5.4 ohm 1x 5.2 ohm 1x 5.0 ohm 1x 4.4 ohm can some tell if some of the plugs are bad??? i have bourgt new plugs, just what to now if the old plugs was bad the plugs are Denso IK22 Iridium Power Spark Plugs Edited May 27, 2015 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 28, 2015 Author Share Posted May 28, 2015 Anyone??? Quote Link to comment Share on other sites More sharing options...
