K22SUP Posted May 19, 2015 Share Posted May 19, 2015 Link to comment Share on other sites More sharing options...
K22SUP Posted May 19, 2015 Author Share Posted May 19, 2015 Fan belt replaced new plugs ordered new fuel filter ordered Link to comment Share on other sites More sharing options...
K22SUP Posted May 26, 2015 Author Share Posted May 26, 2015 1st job done few vacuum hoses replaced new plugs coil connectors ordered as still has misfire then rocker cover gasket I think Link to comment Share on other sites More sharing options...
Supraleeturbo Posted May 26, 2015 Share Posted May 26, 2015 You hope it's just the connectors lol, 9 times out of ten it's the packs! Good luck though fella looks to be a clean supra Link to comment Share on other sites More sharing options...
K22SUP Posted May 26, 2015 Author Share Posted May 26, 2015 We checked all the packs yesterday bud so I hope so lol replace the cheapest first lol Link to comment Share on other sites More sharing options...
K22SUP Posted May 26, 2015 Author Share Posted May 26, 2015 Link to comment Share on other sites More sharing options...
themodifiedkid Posted May 26, 2015 Share Posted May 26, 2015 Well def looks like your rocker cover bolts need nipping up/replacement gaskets!!! Also I'm assuming your either Bpu or going bpu as the heat range of plugs you have would indicate bpu. Looks very clean example Link to comment Share on other sites More sharing options...
K22SUP Posted May 26, 2015 Author Share Posted May 26, 2015 Yeah she already has front mount hard piped Hks 264 cams adjustable pulleys walbro fuel pump fse fuel pressure Reg Hks hi silent exhaust doe pipe cat removed and fcd so am correct in saying if a remove second cat is he is bpu or is it plus ? She runs around a bar just now low boost and 1.2 high I believe this is as high as safe limits ? Link to comment Share on other sites More sharing options...
K22SUP Posted May 26, 2015 Author Share Posted May 26, 2015 And intake and boost controller is Link to comment Share on other sites More sharing options...
themodifiedkid Posted May 26, 2015 Share Posted May 26, 2015 Yep definitely bpu mate. And yes 1.2 bar is the max you want to push those turbos providing they are jspec of course, as uk spec can take 1.4 bar Link to comment Share on other sites More sharing options...
K22SUP Posted May 26, 2015 Author Share Posted May 26, 2015 I thought that no one turbo was replaced in UK years back so it could be metal so to go bpu+ what else is needed Link to comment Share on other sites More sharing options...
K22SUP Posted May 29, 2015 Author Share Posted May 29, 2015 bumper off now a can get it up driveway into garage Link to comment Share on other sites More sharing options...
K22SUP Posted May 29, 2015 Author Share Posted May 29, 2015 engine management light oil light fixed checked for fault codes none [emoji108] Link to comment Share on other sites More sharing options...
K22SUP Posted May 29, 2015 Author Share Posted May 29, 2015 Cam timing set to zero for now running better no hesitation Link to comment Share on other sites More sharing options...
Supraleeturbo Posted May 29, 2015 Share Posted May 29, 2015 did you sort the misfire out mate Link to comment Share on other sites More sharing options...
K22SUP Posted May 29, 2015 Author Share Posted May 29, 2015 I have it sorted a think bud fine plugs and I have coil clips to fit but the biggest thing I have had done was car has adjustable pulleys and 264 cams both were retarded so both are set to zero for now that seems to be biggest part of the issue got a degree ever coming all get cams degreed in properly Link to comment Share on other sites More sharing options...
K22SUP Posted June 8, 2015 Author Share Posted June 8, 2015 Getting cleaned up Link to comment Share on other sites More sharing options...
K22SUP Posted June 10, 2015 Author Share Posted June 10, 2015 coil clips changed Link to comment Share on other sites More sharing options...
K22SUP Posted July 2, 2015 Author Share Posted July 2, 2015 rocker cover was cracked bought one from a member Link to comment Share on other sites More sharing options...
K22SUP Posted July 2, 2015 Author Share Posted July 2, 2015 Few new parts decat ring cam cover Link to comment Share on other sites More sharing options...
K22SUP Posted July 2, 2015 Author Share Posted July 2, 2015 Rocker cover gaskets getting done new rocker bolt seals new crankcase breather hoses as they are all split and cams getting timing set properly with degree wheel and dial indicator Link to comment Share on other sites More sharing options...
K22SUP Posted July 2, 2015 Author Share Posted July 2, 2015 Two new headlights bought side skirts bought pods Link to comment Share on other sites More sharing options...
K22SUP Posted July 2, 2015 Author Share Posted July 2, 2015 Misfire or hesitation still there hopefully maybe removing second cat might be the issue as well and some other gremilins getting sorted out like this Link to comment Share on other sites More sharing options...
Supraleeturbo Posted July 2, 2015 Share Posted July 2, 2015 I'm telling you it's going to be the coil packs mate Link to comment Share on other sites More sharing options...
K22SUP Posted July 2, 2015 Author Share Posted July 2, 2015 Your prob be right but checked resistance ect so am just eliminating things now and dealing with all the stuff that's been shitly repaired over the years Link to comment Share on other sites More sharing options...
