Precision turbo 6766
Supraleeturbo
http://www.ebay.co.uk/itm/151680151204?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D151680151204%26_rdc%3D1#ht_581wt_1190
says new unused , dont look it to me also its an older unit being water cooled dual ball bearing , looks the same as my t6765 dbb just with a different compressor housing , still a very good price for a awsome turbo 1 bar by 4000 rpm
Anyone know if this would be suitable for an na-t? I think .68 will fit under the NA intake
realisticly mate for a n/a-t you would want a smaller turbo this is something lift a 700 hp turbo and most n/a-t go 4-500 before needing silly money
n/a-t also run lower boost due to the higher compression and with larger turbos there afficance range is in the relms of higher boost at least 1.4 +, it would probably fit but way over kill for what is required
I only run mine at a lower boost setting of 1.3 which gets me 524 bhp but i have a 2jzgte and a auto box so have to stop at that power to save my gearbox , if i was doing it again I would just get a newer smaller turbo that would put out 550 bhp at around 1.6 bar
