NA-T FFIM help
bluedrag
hey guys ive finished my NA-T a while a go now but looking at going to a front facing intake however the one that i bought has no location for a IACV do i need to run one for a street car for starters if so whats the easiest way to go about getting one put onto this manifold ive got?
any help is much appreciated =)
what ecu are you using. could you not use a remote idle control valve from another car if using a standalone ecu or another car with a stepper motor type if still on oem ecu?
to fit one it would require welding or tapping fittings before and after the throttle butterfly. i have seen some cars use a valve with hose ends on them but you might need the right type, stepper motor rather than voltage/current/ duty cycle controlled, as i don't know it they would be suitable in a blow motor. sorry can't be of anymore help than that.
regards chris.
