Supra mkiv NA 2jzge start problem and maf
Guest Engesvik
Guest Engesvik
Hey there. I got a problem whit my girlfriends supra.
One is that when it is could I won't start. When I turning the key and the relays just clicks. It can takes about 10-15 minutes until the start motor begins. Anybody that having a clue what It can be?
The other problem is that the there is none air flow sensor mounted on it. There is a apexi open air filter on it. I can't find any contact that looks like it have been to the air flow sensor. Was there any N/A supra whit out air flow sensor or how can I get it back on the car?
Guest Engesvik
It is a j-spec and i got the air temp sensor in the air pipe. So you meaning that the j-spec n/a using a map sensor?
I have removed the starter motors contact and cleaned it. But whit no result. When I tried whit out the contact in it did not obvious clicked in the start motor. And whit it in it did so the solenoid seems to be working?
  • 4 weeks later...
Guest Engesvik
The next problem that have appear is that the fuel pump does not shuts down. When I'm turning the engine off and taking the key out the pump still goes
