HID fitment
Mason
I've done a few searches on here and have found mixed answers just like I'm getting off everywhere else lol, what fitment is needed for my J spec headlights? It says H4 on the actual headlights and a friend of mine is saying the same but then I'm being told I need HB3, anyone run them on a J spec and know exactly which ones I need as getting bulbs should not be this much hassle
Will pull it out and check it when I get home but didn't think it would say fitment on there, was just confused about the headlights saying H4 then being told H4 is for full beam and not what I need for main beam
Are you sure you're car has j-spec headlights fitted? only the UK spec glass headlights should have H4 written on them, if you're not sure post up a pic. What I'm thinking is that your car has been retro fitted with UK spec glass headlights.
They are deffo J spec headlights mate, plastic and faded
Sorry just realised you wrote H4, HB4 is the bulb code for the UK spec headlight low beam.
If they are j-spec headlights then you definitely need HB3/9005 headlight bulbs for the low and high beam. HB4/9006 will not fit as the diameter of the bulb is too wide for the hole in back of the j-spec headlights.
