knock/rattle on idle
jza800
I have a knock that make me crasy..
have taken my engine out off a well running car, only problem was the front main seal, and a blow first turbo, as the shaft got stuck so no boost..
i have fixed all that, and many part have been off because off paint, but everthing is now assembled and the car and engine is now running fine, BUT i have a knock that bother me alittle, maybe i am bearing over concurn over this problem but here it goes..
under idle on hot engine, i heard 1 to 2 knock then it stops again, then it can idle 10 to 15 min with no knock and other times onlt a couple off min, then i hear 1 to 2 knock again, it is not a loud ticking sound, only knock knock.. it is on the 1 cyl it knocks.
somebody have some knowledge what it can be? or does the engine just need to run some miles?? (have been in a enginestand the last 6 months)
Edited by jza800 (see edit history)
i have new pullys from whifbitz purple, and some adjustble timinggear at the camshaft, both setting on 0. the only thing that i keep stock in the harmonic dampener... when i put my ear on the spark plug cover, and i am lucky that it knock when i hear, then it sounds like it is comming from the top end..
I've copied this for you
Most oils on the shelves today are "Multigrades", which simply means that the oil falls into 2 viscosity grades (i.e. 10w-40 etc)
Multigrades were first developed some 50 years ago to avoid the old routine of using a thinner oil in winter and a thicker oil in summer.
In a 10w-40 for example the 10w bit (W = winter, not weight or watt or anything else for that matter) simply means that the oil must have a certain maximum viscosity/flow at low temperature. The lower the "W" number the better the oil's cold temperature/cold start performance.
The 40 in a 10w-40 simply means that the oil must fall within certain viscosity limits at 100°C. This is a fixed limit and all oils that end in 40 must achieve these limits. Once again the lower the number, the thinner the oil: a 30 oil is thinner than a 40 oil at 100°C etc. Your handbook will specify whether a 30, 40 or 50 etc is required.
i have now done some research, and have now found some other than me have knock/rattle in the front, they mentioned the septine belt tensioner , and the timing belt tensioner.. the timingbelt tension idler is new, only the damper that push up the timingbelt idler so the timingbelt is tightened, is the old one, the septine belt tension is also the old one include the damper.. have somebody off you knowledge about they can make rattle/knock sound
