2.5" vs 3" 2nd De-cat
mattdavies
I currently have a 3" 1st decat - RR - 2.5" decat- 3" blitz nur spec setup on from my turbo back and I am BPU
I have been wondering if there any advantage to upgrading the 2.5" de-cat to 3" de-cat ? I have had a look on the interwebs and could not turn anything up. What are peoples thoughts or experiences ?
I would of thought there would be no gain with the way you have it , but if you set it up
3" -3" rr 3", there maybe a little gain
but im sure even with the setup being
3" 2.5" rr 3"
you would gain a litte to as the rr causes a massive restriction almost like a wall but staging down to the 2.5 to the ring acts some what like a funnel , as for the 3" 3" it will have more spare to fill before back preasure is an issue
Replacing the 2.5" 2nd decat with 3" will help the exhaust flow better but it will probably also mean an increase in boost pressure, so you'd need to fit a smaller restrictor ring which would likely cancel out any benefit.
Dont think this would be an issue as should be a 1 bar RR, but I see 0.8/0.9 bar.
So from what I understand ultimately as I have a RR the upgrade to 3" would be negligible due to the RR acting as a air dam
