Engine management light came on after flooring it..
Mason
I've got a 95 N/A, yesterday I noticed the engine management light came on after put my foot down a bit...not sure speeds but then when I came into town roads and backed down to 30 the light went back off, I've checked engine oil and gearbox oil, both seem fine...bridged the ports and the light flicker on the clocks is just continuous which from what I can see means no code recorded, hasn't been converted to mph infact it's pretty much an untouched car.
Think it's something silly or should I be nervous lol
Engine seemed fine no symptoms at all we couldn't find anything wrong...will check the brake fluid but wouldn't have thought that would be a reason for that light to come on
Na the brake one is normally the main red warning light in the middle of the cluster, the little yellow engine management light usually comes on in limp mode or fuel cut
I was gonna say lol, brake fluid is fine took it for a blast last night and nothing...feel like I've wasted good bandwidth making this thread and bothering you guys now but I'm sure it will be back
PS - Your double sixes are distracting me from typing, must have
