ball joint boot dimensions urgently needed
Big Mark
Can some please tell me the dimension of the ball joint boot/cover on this rear arm?
I need the diameter at the bottom (large diameter) diameter of the top (shafter diameter) and the height please.
I got replacement boots for the rest from ebay but didn't for these as they weren't damaged when removed but have gone in to be powder coated so will need to be replaced.
I need to order these today so time is of the essence.
I have done a bit of powder coating at home, and I have to heat to 180 c for 15mins or so. I don't know if this applies to your ball joint but some have nylon or some other type of plastic in them, would they be ok at this heat required to set powder coating?
just tried to measure mine (still fitted to car) the outer dia of rubber boot is approx 36mm so take of about 4mm for inside dia. lenth of rubber boot when fitted is 15mm. as for pin dia i can not measure but would guess at 12-15 going but the nut size that holds the swivel to hub. hope this helps.
regards chris.
