gordy.r Posted May 11, 2015 Share Posted May 11, 2015 Does anyone else or has anyone else noticed cold air coming through from the door handle (drivers side) when either drivers or passengers window is down (even slightly open)? It doesn't bother me as I quite like it, but I was just curious lol. Link to comment Share on other sites More sharing options...
jim Posted May 11, 2015 Share Posted May 11, 2015 Have you had aftermarket speakers or brackets, or a replacement window regulator fitted Gordy? It usually happens when the plastic membrane has been cut (or removed) to fit something. Link to comment Share on other sites More sharing options...
gordy.r Posted May 11, 2015 Author Share Posted May 11, 2015 I'm not sure if I'm honest, speakers etc all seem standard, couldn't comment on regulator unless previous owner had it changed. Cheers for the info though! Link to comment Share on other sites More sharing options...
MattP Posted May 11, 2015 Share Posted May 11, 2015 Yep I had this on my last N/A the plastic Membrane was Cut Link to comment Share on other sites More sharing options...
SupraP-Z Posted May 11, 2015 Share Posted May 11, 2015 I noticed this as well, it quite like it Ive taken the plastic membrane off as my window regulator motor is fubarr, but even when the door card is on air still comes through. As mentioned above, its more likely because of aftermarket speakers. The stock unit air sealed everything in Link to comment Share on other sites More sharing options...
