mellonman Posted May 11, 2015 Share Posted May 11, 2015 We tried using the pops and bangs map on dads auto whilst driving . Didnt seem to run very well . Can it be used driving an auto? yes its still the same vacuum point and rpm, just you wont get it on gear change just over run Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 11, 2015 Share Posted May 11, 2015 yes its still the same vacuum point and rpm, just you wont get it on gear change just over run It sounded like it had a very bad missfire. Might have to try it again for when we have the go pro on Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 11, 2015 Author Share Posted May 11, 2015 Bit of an odd one. Changed the vehicle speed to 0. Watched the map on the laptop whilst blipping the throttle and it goes into the range where it should do something, but nothing. Then change the 1000 -1500 fuel cut in ALS cal2 to 50 percent and its doesn't work, engine runs perfectly. Finally change the ALS cal 1 to exactly the same settings as cal 2. Then change cal Switch to use ALS cal 1 and it works as expected. Why does ALS cal 2 not do anything?? edit to say that pops and bangs is mint though - thats going to be some fun in tunnels Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted May 11, 2015 Share Posted May 11, 2015 Sent the e-mail guys It wont work while driving its meant to be for a launch control.. Vid of mine on my youtube channel (notice how it comes out the twin screamers at the front hehe ) Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 11, 2015 Share Posted May 11, 2015 (edited) It sounded like it had a very bad missfire. Might have to try it again for when we have the go pro on depends on what or how they have mapped your pops and bangs , the map part that is affected is only your vacuum area so should not cause any misfires when driving normally , only when you lift off the throttle . when you say missfire do you mean it popped and banged Edited May 11, 2015 by mellonman (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 11, 2015 Share Posted May 11, 2015 depends on what or how they have mapped your pops and bangs , the map part that is affected is only your vacuum area so should not cause any misfires when driving normally , only when you lift off the throttle . We was only poodling through Southend, so doubt we had enough speed to make it work. Quote Link to comment Share on other sites More sharing options...
kirky_123 Posted May 11, 2015 Share Posted May 11, 2015 It sounded like it had a very bad missfire. Might have to try it again for when we have the go pro on You just need to get someone to turn it up abut more got my car back recently and my pops and bangs was more pops and burbles no bangs, got Ryan G to turn it up a bit now there's some pretty big bangs and flames lol I did ask him to get pops ands bangs when hitting the limiter but it seems like I have no luck with that one Quote Link to comment Share on other sites More sharing options...
Wez Posted May 11, 2015 Share Posted May 11, 2015 It wont work while driving its meant to be for a launch control.. Vid of mine on my youtube channel (notice how it comes out the twin screamers at the front hehe ) Thats launch control / 2 step, not a pops and bang overrun fun map Quote Link to comment Share on other sites More sharing options...
kirky_123 Posted May 11, 2015 Share Posted May 11, 2015 Sent the e-mail guys It wont work while driving its meant to be for a launch control.. Vid of mine on my youtube channel (notice how it comes out the twin screamers at the front hehe ) Yeah I also would like this but was advised it wouldn't be very healthy doing so Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 11, 2015 Share Posted May 11, 2015 this video explains how it works Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 11, 2015 Author Share Posted May 11, 2015 (edited) Paul looks almost the same as mine just on ALS cal 1. Only difference is configured for 8% of the throttle not just sub 4% as on mine. Paul, Guess you don't have oil pressure or oil temp sensors connected to your ECU?? Edited May 11, 2015 by T2 MSW (see edit history) Quote Link to comment Share on other sites More sharing options...
Steve Posted May 11, 2015 Share Posted May 11, 2015 Thats launch control / 2 step, not a pops and bang overrun fun map Email coming your way Wez Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 11, 2015 Author Share Posted May 11, 2015 Email coming your way Wez You need this in your life - its awesome Quote Link to comment Share on other sites More sharing options...
Steve Posted May 11, 2015 Share Posted May 11, 2015 You need this in your life - its awesome Did you keep the settings the same from the map that was emailed over? Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 11, 2015 Author Share Posted May 11, 2015 (edited) Did you keep the settings the same from the map that was emailed over? Yeah Paul's is the same as mine. Only things needed are as below. CAL that turns on ALS set to ALS calibration 1. ALS cal 1 fuel cut at below 4% throttle ALS cal1 ing retard below 4% throttle. Edited May 11, 2015 by T2 MSW (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted May 11, 2015 Share Posted May 11, 2015 You guys getting clever with the syvecs then,,, nice:cool: Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 11, 2015 Author Share Posted May 11, 2015 You guys getting clever with the syvecs then,,, nice:cool: Surprised you have not got it already Quote Link to comment Share on other sites More sharing options...
Guigsy Posted May 11, 2015 Share Posted May 11, 2015 Here is mine on my AEM. no fancy antilag setting. just sat blipping the throttle. No flames just a big a crackle. Not sure id get any flames with a whifbitz 2 box setup. [video=youtube;Un-oETrb3uY] Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted May 11, 2015 Author Share Posted May 11, 2015 roll on the tunnel runs Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 11, 2015 Share Posted May 11, 2015 Me doing pops and bangs in dads supra at JAE. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted May 11, 2015 Share Posted May 11, 2015 My supra banging and flaming at JAE last year https://vimeo.com/127531894 Quote Link to comment Share on other sites More sharing options...
Wez Posted May 11, 2015 Share Posted May 11, 2015 Email coming your way Wez Hey Matey, Just seen this and had a quick look at your map, cal switch 6 is using antilag CAL1 which looks to be setup like overrun bops and bangs, vehicle bypass speed is 10kph but noticed that it is globally disabled, might be worth running by Ryan to see if you can enable it. Quote Link to comment Share on other sites More sharing options...
